Author Topic: Rear triangle injection pump thing.... leaks  (Read 9596 times)
September 21, 2012, 02:02:32 pm
shwak23
  • 417
    • Blackdog Junkyard
« on: September 21, 2012, 02:02:32 pm »
How do I stop it now?
It is the one in the center of the delivery valves. It isn't the 13 mm bolt that is leaking. Its the triangle thing receiving it.
Sent from my DROID X2
Reply #1September 21, 2012, 03:00:37 pm
Re: Rear triangle injection pump thing.... leaks
« Reply #1 on: September 21, 2012, 03:00:37 pm »
Get a 24mm 12 point socket and remove 6 points-3 sets of two points separated by two points that are not removed.  Loosen it.  Swap the o-ring.  Tighten it back up to 55-60 ft-lbs.
Reply #2September 21, 2012, 03:02:43 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Rear triangle injection pump thing.... leaks
« Reply #2 on: September 21, 2012, 03:02:43 pm »
So I can loosen it and swap ring without removing it? What happens if I remove it?
Reply #3September 21, 2012, 03:21:24 pm
« Reply #3 on: September 21, 2012, 03:21:24 pm »
A small amount of fuel might drip out, but otherwise, nothing happens.
Reply #4September 21, 2012, 04:08:21 pm
« Reply #4 on: September 21, 2012, 04:08:21 pm »
You do not have to remove the pump, and removing the large triangular plug will not affect anything inside the pump. Obviously clean the area really well, and don't get any dirt in there. I have these seals on hand, PM me if you would like one. :)
Reply #5September 21, 2012, 08:07:33 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Re: Rear triangle injection pump thing.... leaks
« Reply #5 on: September 21, 2012, 08:07:33 pm »
Hey guys thanks for the advice. I got it all fixed. I had a seal kit here so it all went very quickly.
Reply #6September 21, 2012, 08:20:55 pm
CarlosA
  • 139
« Reply #6 on: September 21, 2012, 08:20:55 pm »
As an aside - what year is this large triangle bolt on? I haven`t seen it on early NA pumps, but I ordered a few Bosch tools and thought i`d throw it in on my next order just to have around.
Reply #7September 21, 2012, 08:23:29 pm
« Reply #7 on: September 21, 2012, 08:23:29 pm »
Nearly every Bosch VE pump, Volkswagen, Land Rover, Cummins, Peugeot.. 1975-200X for sure on the Volkswagen stuff. Yours has it, I guarantee it. Dead center of the delivery valves;
Reply #8September 22, 2012, 10:50:23 am
CarlosA
  • 139
« Reply #8 on: September 22, 2012, 10:50:23 am »
Got it .. I didn't even realize since I haven`t had to remove it. ;)
Reply #9September 22, 2012, 11:23:40 am
« Reply #9 on: September 22, 2012, 11:23:40 am »
There is an O ring behind there that is subject to the high pressures of the pump.. So next time you are able i suggest changing it :).
Reply #10September 22, 2012, 11:45:15 am
« Reply #10 on: September 22, 2012, 11:45:15 am »
doesnt it see the INJECTION pressures? and not the internal pressures?
thats gotta be a pretty damn tough o-ring..
Reply #11September 22, 2012, 01:08:35 pm
« Reply #11 on: September 22, 2012, 01:08:35 pm »
No it doesn't see injection pressure.  The big triangular nut does a metal on metal seal around the end of the plunger bore.  The o-ring just seals internal pressure. I don't think there are any rubber o-rings made that will withstand injection pressure.
Reply #12September 22, 2012, 01:09:46 pm
« Reply #12 on: September 22, 2012, 01:09:46 pm »
Should have specified the high internal pressures, not injection pressure.
Reply #13September 22, 2012, 01:11:22 pm
« Reply #13 on: September 22, 2012, 01:11:22 pm »
but the plunger is directly behind the triangle nut..
how does it NOT see plunger pressure?!
we are talking about the triangular nut that we screw our adapter into to check timing, right?
Reply #14September 22, 2012, 01:45:01 pm
« Reply #14 on: September 22, 2012, 01:45:01 pm »
Like I said, the triangular nut seals metal on metal to the end of the bore of the plunger.  There is a thin machined ridge that seals against the distributor head.  The o-ring is outside that metal on metal seal and merely seals the edge of the triangular nut against internal pressure.  The area of the triangular nut inside the metal sealing ridge sees injectionl pressure, but the o-ring does not.
« Last Edit: September 22, 2012, 01:49:51 pm by libbydiesel »
