Author Topic: Serpentine Belt Length  (Read 2529 times)
September 21, 2012, 11:36:40 am
ein bora
  • 377
« on: September 21, 2012, 11:36:40 am »
I"m looking to buy a serpentine belt for my azz, one without air conditioning. When searching for a non a/c belt -  I'm finding belts of all different lengths?  As I don't have an old belt to measure off of, would anybody know the right length that I will need.
Thanks.
If you can't take advice - then you can't be helped!
Reply #1September 21, 2012, 11:43:45 am
srgtlord
  • 797
Re: Serpentine Belt Length
« Reply #1 on: September 21, 2012, 11:43:45 am »
I beleive its 1045? somebody correct me if im wrong.
Reply #2September 21, 2012, 12:23:15 pm
ein bora
  • 377
« Reply #2 on: September 21, 2012, 12:23:15 pm »
No you are right - did some more digging and the consensus is 21.36 x 1045
Thanks much!
Reply #3September 21, 2012, 02:07:03 pm
« Reply #3 on: September 21, 2012, 02:07:03 pm »
i believe i had to run a 1038 or something..
lemme go run up and check..
ive got a 1040mm belt on my car..
it says this belt is more commonly used on 1984 ford tempo, and mercury topaz with a/c.. and 1990 taurus w/ 1.9L
i had a 1054mm belt at first, and it was just a touch too long..
so, a 1045mm belt should be just about right..
« Last Edit: September 21, 2012, 02:14:00 pm by R.O.R-2.0 »
Reply #4September 21, 2012, 05:19:18 pm
CrazyAndy
  • 739
« Reply #4 on: September 21, 2012, 05:19:18 pm »
Pardon the question, but didn't you have a similar thread you made or posted in a month or two ago about exactly this topic?
OT, I think you said 1035-1038 or around that, as 1045+ got too close to the water pump pulley.
Reply #5September 21, 2012, 05:25:11 pm
« Reply #5 on: September 21, 2012, 05:25:11 pm »
yea, we went over all of this a couple months back..
the OP doesnt know how to use the search function, because there was alot of discussion about it!
Reply #6September 21, 2012, 05:27:00 pm
« Reply #6 on: September 21, 2012, 05:27:00 pm »
