Author Topic: Main pump head seal size  (Read 2064 times)
September 18, 2012, 03:05:00 am
regcheeseman
  • 714
« on: September 18, 2012, 03:05:00 am »
Need to get some ordered today, thought I had the information at work but cannot find it....tried a search with no joy
The main pump head o-ring seal it's 68mm O.D. with a 2.5mm wall isn't it?
edit: soem googling has netted me Zexel part number 146600-0000 which is quoted as being 60mm x 2.62mm
Not sure if 60 is the ID or OD???
« Last Edit: September 18, 2012, 07:21:13 am by regcheeseman »
Reply #1September 18, 2012, 09:20:48 am
Re: Main pump head seal size
« Reply #1 on: September 18, 2012, 09:20:48 am »
Good to know. Did you find a supplier? How much are they?
Reply #2September 20, 2012, 01:32:48 am
regcheeseman
  • 714
« Reply #2 on: September 20, 2012, 01:32:48 am »
No turns out that the internet is wrong - as the bore on the pump housing is near 68mm - so the bag I had my last lot in with the faded handwritten dimensions of 68 x 2.5 may well be what I have been using
I bought 25 from my local bearing stockist - for less than £5. This was 3-4 years ago, had no reported failures.
