Author Topic: Here is the PDF: ProTraining: Four Cylinder DIESEL 77-83  (Read 16988 times)
Reply #15October 01, 2006, 06:06:02 pm
« Reply #15 on: October 01, 2006, 06:06:02 pm »
Thank you very much  :D
Reply #16October 01, 2006, 06:16:59 pm
SmokeyCJR
  • 8
« Reply #16 on: October 01, 2006, 06:16:59 pm »
this is so helpful thanks for your time.
Reply #17October 05, 2006, 09:53:09 am
HarryMann
  • 170
« Reply #17 on: October 05, 2006, 09:53:09 am »
top job, thanks
Reply #18October 08, 2006, 08:21:19 pm
3play
81 rabbit D
« Reply #18 on: October 08, 2006, 08:21:19 pm »
Thanks for the manual, I discovered it by accident, but I will need it.
I just aquired an 81 diesel rabbit and it is a mosquito fogger on wheels!!!
It starts easily and seems to run strong, but it has a serious smoking habit.
It also needs a tranny, it is sticking in most gears.....
Are the trannies worth rebuilding, or should I look for a used one?
Is there a procedure for isolating the smoke problem, or should I do the top end???
Any info would be welcomed....
MM
Reply #19October 08, 2006, 09:08:26 pm
coke
  • 254
« Reply #19 on: October 08, 2006, 09:08:26 pm »
What color is the smoke?
Reply #20October 08, 2006, 10:04:11 pm
« Reply #20 on: October 08, 2006, 10:04:11 pm »
I'd check the shift linkages before the tranny's... the tranny's will take a lot of abuse (unless of course the car is highly modded for power  :twisted: )
**My shift linkage was really 'gummy' when cold, but really nice and loose when warm.  I got the car oil sprayed by rust check, and they lubed it all up!  now my shifter is loose when cold too...  couldn't hurt to get your tranny oil changed too... most people here recommend redline synthetic.
as for the smoke... maybe someone turned up the fuel screw??? low compression will give a lot of smoke as well.  Think of black smoke as unburnt fuel.
It is also bad to be smoking too much because of the abrasiveness of the soot carbons that mix with the oil.   The oil filter does a poor job at getting the tinier particles that do most of the damage to the motor.
oh yea.. I'm just guessing the smoke is black.  If we're talking white, then you got some bad injectors/compression :cry:
Reply #21October 10, 2006, 09:13:33 pm
3play
« Reply #21 on: October 10, 2006, 09:13:33 pm »
Quote from: jtanguay
This tranny was mostly sticking in 3rd, to the point that you had
to hammer the top lever on the tranny to get it out, then it started sticking in the rest of the gears, I was told that this is a typical failure mode for the tranny...
The engine smoke is grey, not black and it doesn't smoke too much once it is fully warmed up.
MM
Reply #22October 10, 2006, 09:17:10 pm
3play
« Reply #22 on: October 10, 2006, 09:17:10 pm »
Quote from: 3play
PS, is there a standard metal replacement for the ^&%#* plastic "hiem" type linkage to the shift arm?
I broke the plastic link when hammering the tranny out of gear......
If I knew it was plastic, I would have tried to be more careful, but I have never seen a plastic linkage like that before....
MM
Reply #23October 10, 2006, 10:07:26 pm
« Reply #23 on: October 10, 2006, 10:07:26 pm »
im not sure about a metal aftermarket shift linkage system.
i had second gear stick on me... 3rd was never really a problem.. but my 2nd gear synchronizer is pretty much fried... as it grinds sometimes if i dont let the rpms drop.. but it still drives fine!  I just changed the tranny oil.  i hate 1st to 2nd gear on my tranny :(
Reply #24October 08, 2007, 07:57:42 pm
bmatthis1
  • 5
Injection Pump pdf
« Reply #24 on: October 08, 2007, 07:57:42 pm »
Does anyone still have this pdf file available for some of us newbies that missed the original?
Thanks!
Reply #25October 08, 2007, 08:06:11 pm
blkboostedtruck
  • 1535
« Reply #25 on: October 08, 2007, 08:06:11 pm »
yea I can't access it either? says not found! Tyler, do you still have it?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #26October 08, 2007, 08:24:47 pm
« Reply #26 on: October 08, 2007, 08:24:47 pm »
No I lost it in my reformat
Reply #27October 08, 2007, 08:43:02 pm
« Reply #27 on: October 08, 2007, 08:43:02 pm »
I'll host... was about to launch my HOW-TO site soon.. now's as good a time as ever....
Reply #28October 08, 2007, 10:10:05 pm
« Reply #28 on: October 08, 2007, 10:10:05 pm »
Will be hosting real soon now... uploader appears to be busticated at the moment.... working on it...
Reply #29October 09, 2007, 02:30:51 am
Ziptar
  • 565
« Reply #29 on: October 09, 2007, 02:30:51 am »
I have some free bandwidth left for the month. I can host it for a bit.
http://www.ziptar.com/pro_train/protraining_diesel_77-83.zip
