Author Topic: pros and cons 1.6td vs 1.9aaz vs tdi.  (Read 58060 times)
Reply #30May 20, 2016, 08:20:43 am
Re: pros and cons 1.6td vs 1.9aaz vs tdi.
« Reply #30 on: May 20, 2016, 08:20:43 am »
Why would you need to send Giles an LR pump AND a 1.6 pump?  The LR pump does not need any components from the 1.6 pump.  Is he collecting 1.6 pumps?  Just run the LR pump.  No need to send it to anyone...
Reply #31May 23, 2016, 06:47:08 pm
SR Heer
  • 199
« Reply #31 on: May 23, 2016, 06:47:08 pm »
Good call Libby -
I checked with Gee Bee and it wasn't a 1/6TD pump that he had sent along with the Rover pump to Giles for high performance custom build but an AHU pump along with a Rover for like $2200 - so I don't know if rebuilding  both or turning them both into one supper custom build pump for that much - anyway nix the 1.6TD pump info I gave out - not totally understanding Guy but that's because correspondence was vague -
Reply #32May 24, 2016, 12:40:11 pm
« Reply #32 on: May 24, 2016, 12:40:11 pm »
I asked Giles a couple years ago, here's his answer:
yes we are building M-TDI pumps and yes we need two donor pumps for sure.
a TDI pump and an AAZ pump to make the base pump from.
cost is $1400 with you sending in the two pump cores, if you need them we have for $350 each
it comes with the the TDI original head, if you want a bigger one I would have to purchase one from Bosch  $1000 more
Giles
Performance Diesel Inj.
The Fuel Injection Specialists
905-940-2266
No Rover pump required.  The only possible reason to send Giles a Rover pump plus something else would be to put the Rover guts into a housing with the smaller nose that fits the stock AHU bracket without modification.  I certainly wouldn't spend my money that way.
« Last Edit: May 24, 2016, 12:43:43 pm by vanbcguy »
