Author Topic: exhaust studs keep braking  (Read 5318 times)
Reply #15September 11, 2012, 09:10:12 pm
hillfolk'r
  • 1532
Re: exhaust studs keep braking
« Reply #15 on: September 11, 2012, 09:10:12 pm »
i wanna say the tq is 18 ft  pounds...or it could be 11...crap i cant remember...someone will post though id bet...
actually you do not wanna use grade 8 fastners...they are too hard and dont expand enough or the same as the manifold and turbo...grade 5 stuff is ok..thas wat i lurned in tek skool n stuff..yea you would think ya want hardened stuff,but just the opposite,ya need flex for heat expansion
Throttle cables ftw
Reply #16September 12, 2012, 12:31:21 am
  • 2931
« Reply #16 on: September 12, 2012, 12:31:21 am »
Got the fatty exhaust washers?
Reply #17September 12, 2012, 04:04:07 am
jeff115
  • 19
« Reply #17 on: September 12, 2012, 04:04:07 am »
yes
never would have thought that.
« Last Edit: September 12, 2012, 04:07:41 am by jeff115 »
Reply #18September 12, 2012, 06:24:03 am
Alcaid
  • 549
« Reply #18 on: September 12, 2012, 06:24:03 am »
Kinda offtopic, but what T3 are you running?
'10 VW Passat 1.6TDI Highline
Reply #19September 12, 2012, 06:26:50 am
« Reply #19 on: September 12, 2012, 06:26:50 am »
Yeah from what hillforlk'r says is accurate. The Grade 8 are much stronger, but lack stretch. You will get way more clamping force with a Grade 8, but if the tensile of the fastener is 120,000 psi it will usually break past that. Grade 5 on the other hand is lots less tensile at around 80,000 but it will give some before it breaks. It will stretch and deform, where the grade 8 will just call no joy and give it up.
If you still need the bentley spec I will get it later if you ask.
Reply #20September 12, 2012, 06:58:06 pm
jeff115
  • 19
« Reply #20 on: September 12, 2012, 06:58:06 pm »
Probably wont need the torque specs I stopped at oreily's today and got some 3/8-16 header bolts so hopefully that helps.
I have run several so far I had a t3to4e from ebay and it sucked. pretty close to the stock t3, but a little bit more laggy. then I had an ebay gt15, witch was left on for the longest because it worked good. drove it for about a month @26 psi still running strong but I wanted to try something else so now I have an ebay gt28rs. hopefully ill have the manifold all sorted out to see how it works this weekend.
the first two ebay turbos I used because I had them...
they didnt leak oil or blow up like I allways here and I pushed the gt15 pretty hard in bad conditions. so I have faith in them. well see how this new one works.
specs are
compressor                 turbine
inducer   54.13mm   inducer   52.00mm
exducer   70.00mm   exducer   45.00mm
Reply #21September 12, 2012, 08:42:10 pm
« Reply #21 on: September 12, 2012, 08:42:10 pm »
please dont thread your head for 3/8-16 bolts!
bolts are worse than studs..
Reply #22September 12, 2012, 09:03:46 pm
hillfolk'r
  • 1532
« Reply #22 on: September 12, 2012, 09:03:46 pm »
yea stick with the studs fer sur...just like head studs,they are better than bolts,sothe same applies for the exhaust(or most any application)...even though i graduated from tech school in 97,there isnt a day that goes by im referring  back to what i got learned :)
still gettin learned every day too!
not like you would have to but repeated removal/install of" bolts" would start to wear out the head.
Throttle cables ftw
Reply #23September 13, 2012, 08:22:11 am
TurboJ
  • 661
« Reply #23 on: September 13, 2012, 08:22:11 am »
Here's a pic of turbo braces:
http://aki76.kuvat.fi/kuvat/vento+TTSI/09042012027.jpg
Aki's work once again.
Ball bearings work great as they allow small margin of movement - will not cause breaking of brace joints.
Jetta II 1.6 TD 'Project 200'
Reply #24September 13, 2012, 12:11:41 pm
« Reply #24 on: September 13, 2012, 12:11:41 pm »
yea, the head is REALLY SOFT aluminum..
the bolts are REALLY HARD steel..
the steel wins every time..
nothing like taking a header bolt out, and finding a coil of aluminum wrapped around the threads, that USED TO BE the threads from the head..
