Author Topic: WTB 068130365A cruise control connecting link.  (Read 4148 times)
September 10, 2012, 05:26:34 pm
« on: September 10, 2012, 05:26:34 pm »
It is a wire bit about 3 inches long and an inch wide. There are two floating black plastic clips that hold on to the end of the cruise and the throttle.
It looks like part #35
 part number 068130365A
Mine won't stay on the ball ends any more, there are fingers broken.
It is for my 86 jetta.
Thanks
Reply #1September 10, 2012, 07:12:25 pm
Re: WTB 068130365A cruise control connecting link.
« Reply #1 on: September 10, 2012, 07:12:25 pm »
I think Giles has one on the shelf.
Reply #2September 10, 2012, 07:48:23 pm
« Reply #2 on: September 10, 2012, 07:48:23 pm »
they wear out... a piece of cable, 2 eye lets... your golden... just make sure the cable flexes/bends easily... need it to deform when go pedal pressed... turning cruise on pulls it tight...
Reply #3September 10, 2012, 08:06:46 pm
« Reply #3 on: September 10, 2012, 08:06:46 pm »
Thanks burn your money and burnt toast,
I'll give giles a heads up.
I had thought about just making a link up. Frankly I am a bit worried about the link hooking around something like the fuel inlet. There isn't much room below the link on my car.
Reply #4September 11, 2012, 06:09:17 pm
bbob203
  • 1789
« Reply #4 on: September 11, 2012, 06:09:17 pm »
get pedal and actuator assembly from a passat b3 or b4. it moves the diaphragn inside the car and frees up a little space under the hood.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #5September 18, 2012, 03:59:42 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #5 on: September 18, 2012, 03:59:42 pm »
Sounds the same as the Corrado setup.
Reply #6September 19, 2012, 02:12:42 am
bbob203
  • 1789
« Reply #6 on: September 19, 2012, 02:12:42 am »
that it is.
03 Jetta wagon TDi
Reply #7September 19, 2012, 06:14:36 am
« Reply #7 on: September 19, 2012, 06:14:36 am »
Here is what I ended up doing.
http://www.vwdiesel.net/forum/index.php?topic=32107.0
Thanks
