Can someone give me the correct name for that manifold?
Topic: Can someone give me the correct name for that manifold? (Read 4633 times)
February 19, 2006, 02:36:41 pm
16V-Sauger
February 19, 2006, 02:36:41 pm »
what is such a thing called in english?
it has 2 plenums which are seperated by a little gap.
we call it "Spaltsaugrohr" but i didn't found anything on the net how this could be called in english :oops:
February 19, 2006, 02:48:31 pm
DieselMonkey
February 19, 2006, 02:48:31 pm »
:lol:
In English, Spaltsaugrohr, means - 'Gap Suction Pipe' as provided by 'free translation'.
thats obviously a great help ! I think i'll go and ask my local VW parts man for a Gap suction pipe, i'll assure him its on ETKA somewhere !
DM
February 20, 2006, 01:34:49 am
16V-Sauger
February 20, 2006, 01:34:49 am »
so, maybe its correctly translated but if you can't find pictures in google while searching for that word, it can't be correct
February 20, 2006, 01:50:47 am
fspGTD
February 20, 2006, 01:50:47 am »
It is hard to tell from the picture what is going on there, but I'll take a stab at it...
If there is a valve between the two plenums that opens and closes, it sounds like a "variable intake manifold" (or sometimes just called "variable intake") that could be more specifically referred to as a "resonance intake system":
http://www.autozine.org/technical_school/engine/tech_engine_2.htm
If it's something else, can you explain more about how it works?
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
February 20, 2006, 03:05:04 am
16V-Sauger
February 20, 2006, 03:05:04 am »
these intakes were used at WRC cars. the two plenums are seperated by a little gap. the boosted air gets into the tapered plenum and flows through that little gap into the second and larger plenum. from there it goes into each intake runner.
i found a few pics which may show it a little bit more precisely
http://ww3.cad.de/foren/ubb/uploads/Tschokko/ssr4_1.jpg
http://ww3.cad.de/foren/ubb/uploads/Tschokko/ssr4_2.jpg
http://ww3.cad.de/foren/ubb/uploads/Tschokko/ssr4_3.jpg
these intakes were used to guarantee that each cylinder gets exact the same volume of air. maybe not toooooo interesting on a diesel, but very important on a FI gasser
February 20, 2006, 12:02:11 pm
veeman
February 20, 2006, 12:02:11 pm »
Hmmm... interesting photo. I remember seeing a bit about these style intakes from a guy who restored an original Audi rally car (James_Bufkin) Here's what he says...
"The primary lower plenum with connects to the throttlebody is gradually tapered like a cone with a continuous single vent slot that allows gas to pass into the 2nd plenum. The 2nd plenum acts as a collector which then feeds the runners to the head. Pressure in the 2nd plenum is equallized since its not effected by gas velocity and inertia or the pressure variation from front to back of the 1st plenum. Since flow equals velocity times area. The reduction in flow which is released through the side slot is equal to the reduction in area of the plenum assuming velocity is constant. So a smooth conical taper with establish equal pressure and air distribution into the 2nd plenum."
There are a bunch of pics and some nice looking fab work on the older Audi rally cars at his site...
http://www.bufkinengineering.com/intake%20manifolds.htm
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
