Author Topic: This mecanical pump will work?  (Read 8501 times)
May 10, 2004, 04:04:12 pm
GTDi
  • 6
« on: May 10, 2004, 04:04:12 pm »
Is from a land rover 300tdi and the bosh number is  0 460 414 136 and in the bottom 509-3
Will this pump work? Need some modification?
Thx
VW Golf GTDi
VW Corrado G60
Mitsubishi Pajero TDi
Reply #1May 10, 2004, 04:29:05 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
« Reply #1 on: May 10, 2004, 04:29:05 pm »
This pump 'turn' in the right direction, if it's bolt on the bracket, it should works.. But you have to try.. :)
FYI : VE4/11F2000R509-3 ( pump info )
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #2May 14, 2004, 12:13:44 am
Anonymous
« Reply #2 on: May 14, 2004, 12:13:44 am »
I sure hope it will work. I bought one for my swap.
Reply #3May 14, 2004, 12:56:48 am
caddy
  • 748
« Reply #3 on: May 14, 2004, 12:56:48 am »
be carful with range or land rover pump, some of them turn in wrong side! :?
that a good new if the 300 tdi turn in wright side!! :D
