Author Topic: 1.9 and 1.6 pics of crank combinations  (Read 9871 times)
August 26, 2012, 07:26:14 pm
« on: August 26, 2012, 07:26:14 pm »
I have 2 pics here, it is a 1.6 block and a 1.9aaz crank. I know it has been discussed before, but I never had pics before. I figured I would share. Basically, the 1.6 block and big rod end work with the 1.9 crank. The 1.9 crank fits into the 1.6 block. You would have to find rods to make it go, but I think it could be done. Someone *think fatmobile* did it and the 1.7 rods were used??? Anyhow, it is something for some of you to work on  ;D
Reply #1August 27, 2012, 02:09:31 am
Alcaid
  • 549
Re: 1.9 and 1.6 pics of crank combinations
« Reply #1 on: August 27, 2012, 02:09:31 am »
The 1.7 rods where the same as the 1.6 rods, same rod and crank, just different bore.
With a longer stroke in the 1.6 short block, one would have to make deeper piston reliefs for the oil cooling jets. Don't know if this is a show stopper or not.
Why even consider putting in the heavy 1.9 crank in a 1.6? That's the main benefit of going the 1.6 route!
'10 VW Passat 1.6TDI Highline
Reply #2August 27, 2012, 05:04:05 am
« Reply #2 on: August 27, 2012, 05:04:05 am »
I am not doing it. I think I will go TDI from now on, but I just wanted others to know what is possible or the start of it.
I think a stroker diesel would be neat. If I were continuing in the IDI stuff I would do it. Every stroker engine I have been around always has tons of torque, which our diesels have already, but you can never have enough IMHO.
« Last Edit: August 27, 2012, 05:33:39 pm by theman53 »
Reply #3August 27, 2012, 06:04:12 am
Alcaid
  • 549
« Reply #3 on: August 27, 2012, 06:04:12 am »
Stroker engines gets more torque from the longer stroked crank (Force x Arm), NOT from the weight of the crank or flywheel...
Reply #4August 27, 2012, 06:13:03 am
« Reply #4 on: August 27, 2012, 06:13:03 am »
http://pagparts.com/product_info.php?cPath=34_35&products_id=74
Looks like these guys will make a "vr6" rod any size you want it.
« Last Edit: August 27, 2012, 05:24:05 pm by theman53 »
Reply #5August 27, 2012, 07:46:32 am
« Reply #5 on: August 27, 2012, 07:46:32 am »
IIRC fatmobile's engine used the 1.7 pistons in the 1.6 block with the 1.6 crank.  I don't recall hearing about it being finished and running.  Anyway, did you install the rods on the crank with it in the block?  I'm seriously surprised if the rods don't interfere with the case.  On the 1.9, the block is bubbled A LOT to give rod clearance for the added stroke.  If they would clear, you'd probably end up with displacement somewhere around 1.75L
Reply #6August 27, 2012, 05:27:47 pm
« Reply #6 on: August 27, 2012, 05:27:47 pm »
I did not put the rods on it in the block, so I don't know if it would fit inside the crankcase. Might be some notching required, probably dependant on the rods used. The one issue I did think I saw was the rod where the IM shaft gear is may have interference. I know the crank did rotate well and looked like it had plenty of room on the rod journals without hitting.
Just wanted to make a thread that stated it was a possibility, that is all.
Reply #7August 27, 2012, 05:42:06 pm
« Reply #7 on: August 27, 2012, 05:42:06 pm »
Something maybe more interesting would be a 1.6 crank in a 1.9 aaz...big bore instead of a stroker.
Reply #8August 27, 2012, 06:20:36 pm
« Reply #8 on: August 27, 2012, 06:20:36 pm »
Yes I did the math before, I forget the combo of pistons and rods but u can do it and only need to take 5-10mm off the deck, not quite the entire 16mm difference of the newer block.
Reply #9August 27, 2012, 06:25:35 pm
MJF
  • 581
« Reply #9 on: August 27, 2012, 06:25:35 pm »
Already done it few years ago. With 1,9 NA pistons and ~154mm rods.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #10August 27, 2012, 06:27:17 pm
« Reply #10 on: August 27, 2012, 06:27:17 pm »
The 1.7L KY is the bore of the 1.9 and the stroke of the 1.6.
Reply #11August 27, 2012, 06:42:35 pm
« Reply #11 on: August 27, 2012, 06:42:35 pm »
if you want a stroker, then use the tall block. not the short block..
thats why huge chevy strokers have blocks with much taller decks.. more room for displacement..
making a stroker out of a short block is a BAD IDEA..
Reply #12August 27, 2012, 06:45:22 pm
« Reply #12 on: August 27, 2012, 06:45:22 pm »
Perfect.
MJF was it all stock parts the 1.9 n/a rods and pistons or was it some other combination? Also, you did use the 1.9 block not the 1.6 right? I would think you would have to sleeve the 1.6 to accept the 1.9 pistons as there wouldn't be enough meat to bore. I suppose if one did that they could in theory keep the 1.6 block, crank, rods, and just have it a huge bore.
Reply #13August 27, 2012, 11:23:12 pm
Alcaid
  • 549
« Reply #13 on: August 27, 2012, 11:23:12 pm »
Tall block with 100mm crank and 141.75mm rods, it's already been done on the TDI engines so would be cool if someone made a similar AAZ ;D
Reply #14August 29, 2012, 04:33:47 am
MJF
  • 581
« Reply #14 on: August 29, 2012, 04:33:47 am »
I used AAZ block and some Honda journal Nascar SBC connecting rods.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
