Author Topic: AAZ/1.6 IDI block head studs same as ALH?  (Read 3793 times)
August 25, 2012, 11:43:59 am
  • 3468
    • McScrubbins Body Wash
« on: August 25, 2012, 11:43:59 am »
I have my ARP head studs from my AAZ that i'm parting out because I aquired a 2000 ALH.
Will the head studs cross over?
I need to delete the EGR and clean out the head and intake so I may as well.
Reply #1August 28, 2012, 09:15:06 pm
Re: AAZ/1.6 IDI block head studs same as ALH?
« Reply #1 on: August 28, 2012, 09:15:06 pm »
No need to remove the head while doing that clean up Ed, it can be done on car easily.
Reply #2August 29, 2012, 04:27:48 am
« Reply #2 on: August 29, 2012, 04:27:48 am »
They make studs now for the TDI's but before then the same ones for the 1.6 worked in them. For reference check for the stock head bolts for the 1.6 and the 1.9. It should be 068103384A for both, so you know they work in both.
Reply #3September 22, 2012, 06:05:19 pm
  • 3468
« Reply #3 on: September 22, 2012, 06:05:19 pm »
That's hilarious because my parents paid the dealership to do it three times in the last 12 years and it cost in excess of $1,000 each time.
Just based of that three digit figure i was guessing it was hard to do or at the very least harder than if it was an IDI...
