Author Topic: Need a new block  (Read 7324 times)
Reply #30August 30, 2012, 08:20:55 pm
  • 2931
Re: Need a new block
« Reply #30 on: August 30, 2012, 08:20:55 pm »
 I have never even stripped out or cracked 11mm bolts when reusing the stock bolts
 and have put a VNT-15 with the vanes locked closed on a 1.5L block with ARP headstuds.
 Boosted to 35 with the great backpressure of a VNT working against it,.. a couple times. With no adverse effects.
Sidenote: I replaced the stock headbolts 1 at a time withy ARP headstuds and was worried it might leak but it worked great.
 My TD Golf by comparison has 12mm raceware headstuds ,... oil seeping from the front and I retorqued them after seeing coolant coming up around the threads of a stud.
 I think Andrew just got a bad 11mm block.
Reply #31August 31, 2012, 04:29:29 am
rs899
  • 647
« Reply #31 on: August 31, 2012, 04:29:29 am »
I am about to try pushing my luck on an 11mm block and factory bolts.  I have done 3 or 4 in the past with no issues.  Ignorance used to be bliss 20 years ago (before the internet).
Reply #32August 31, 2012, 06:49:27 am
« Reply #32 on: August 31, 2012, 06:49:27 am »
I guess that's the easy out.  Yes, it was a bad 11mm bloc, IMO they all are...  It was during a head gasket change, so I didn't have the block magnafluxed, but I did clean the deck surface meticulously and inspected around all the bolt holes with a light and magnifying glass.  I prepped each bolt hole meticulously and torqued the ARP studs to spec.  All for naught.
Reply #33August 31, 2012, 10:10:59 am
« Reply #33 on: August 31, 2012, 10:10:59 am »
i boosted up to 35 many a time..
its not till i boosted it up and left it there for a mile or so, that it popped..
popped somewhere north of 40psi.. 30psi is at like 4'oclock on my gauge, well, i had it almost wrapped back to the 0 peg.. lol.
blew a chunk clear out of the head gasket..
and the #4 end of the block was TRASHED..
