Author Topic: Pop Tester Wanted!  (Read 8414 times)
Reply #15August 28, 2012, 09:04:30 am
rs899
  • 647
Re: Pop Tester Wanted!
« Reply #15 on: August 28, 2012, 09:04:30 am »
I made my pop tester out of a grease gun- unscrewed the long probe and found an appropriate fitting and gauge from McMaster- Carr.   Used a hard fuel line for the injector.
There's a plan for this over at Peach Parts, maybe about 7 years back...
Reply #16August 28, 2012, 02:34:52 pm
CarlosA
  • 139
« Reply #16 on: August 28, 2012, 02:34:52 pm »
Yeah I think the grease gun is the way to go if I can crush the leaks .. I have a nice expensive NAPA grease gun that seems to be well made, could give it a shot.
I`m watching another pop tester for sale and will decide after it ends. ;)
Reply #17August 28, 2012, 08:17:14 pm
JFettig
  • 82
« Reply #17 on: August 28, 2012, 08:17:14 pm »
I just picked up a pop tester from ebay, I'll give a short review when I get it.
Does anyone have a source for TDI shims?
Reply #18August 28, 2012, 08:43:46 pm
CarlosA
  • 139
« Reply #18 on: August 28, 2012, 08:43:46 pm »
Did you get the one that is made in India? I have/had one of those .. but its a long way from where I am, lol.
I will be in New Delhi India in January and may try to visit their place and see wtf is up with Bosch genuine testers being built there.
Shimzzz
Reply #19August 29, 2012, 04:33:49 am
JFettig
  • 82
« Reply #19 on: August 29, 2012, 04:33:49 am »
I did. Did you have issues with yours?
Thanks for the link on the shims, do you know what the inside diameter of those are?
Reply #20August 29, 2012, 10:39:22 am
CarlosA
  • 139
« Reply #20 on: August 29, 2012, 10:39:22 am »
I don`t know anything about the TDI shims.
The tester works and operates exactly like the Bosch branded ones i`ve used ... except the India tester has an option for a better gauge - with finer graduations. I think that is an excellent thing to have when trying to dial in a set of injectors as closely as possible. The india tester also uses a Bosch delivery valve and can be resealed with standard viton o-rings. The only thing that might be of concern is their quality check .. in terms of paint, casting, etc - taking it apart and cleaning/lubing it at some point might just be peace of mind!
Reply #21August 29, 2012, 11:17:36 am
JFettig
  • 82
« Reply #21 on: August 29, 2012, 11:17:36 am »
Thanks for the info!
TDI Shims are 3mm(minus a little) ID, 7mm(plus a little) OD. The ones I measured were between .060 and .070" thick.
I sent that shim supplier an e-mail, hopefully they can answer my question, those shims are super cheap compared to the other quote I got.
I'll post a little review when I get the pop tester.
Reply #22August 29, 2012, 12:21:23 pm
CarlosA
  • 139
« Reply #22 on: August 29, 2012, 12:21:23 pm »
Yeah that is the best place for shims in my opinion - but watch out for their shipping, I believe they have a $14 minimum shipping charge to US, plus the exchange rate puts you up there. I am going to place another order to get some heat shields for around 70 cents each & probably throw in a couple Bosch VE pump tools to make it worth it.
Reply #23September 05, 2012, 08:40:58 pm
JFettig
  • 82
« Reply #23 on: September 05, 2012, 08:40:58 pm »
Got my pop tester yesterday! Got it all set up today.
First off, the gauge is huge, which is quite nice. I am having issues with the check valve holding, I can remove it and put it back in and it works for a little while but its looking like I'll have to take it apart again to try and figure it out. The lock out valve seat also needs some work, it doesn't always seal unless I crank on it hard.
I pop tested various injectors, 2 old stock sets, they all streamed to a certain point, one set  with 40k on them, 2 of the 4 stream, and I installed a single HFLOX Warp 5 nozzle on one body(from a stock set) and it popped nicely at 210bar.
I'll pull it apart and clean it up and report back.
Reply #24September 06, 2012, 05:14:09 pm
JFettig
  • 82
« Reply #24 on: September 06, 2012, 05:14:09 pm »
Short review.
Poor quality! won't hold pressure(injectors are good), Parts are poorly machined. Threads mashed or stripped. The valve on the side is just spins after not many uses, threads are completely stripped out. I'm very disappointed! If I can't get good parts from them, I'll have to machine my own.
There are no Bosch parts on this thing, none. Now lets see if they'll replace the bad parts(don't want to ship this thing back to india!)
Reply #25September 12, 2012, 09:58:17 am
JFettig
  • 82
« Reply #25 on: September 12, 2012, 09:58:17 am »
update to the review:
The needle for the gauge shut-off was supposed to be M12x1.25 but it was more like M11x1.25 I turned a new one and its working. I also had to clean up some threads on other parts of it. I contacted the seller and they are sending me a bunch of new parts free of charge.
I haven't used it much lately but it appears to do the job and the resolution on the gauge is awesome, I wish it wasn't so slow to react - I might drain the glycol.
Reply #26September 12, 2012, 11:18:49 am
« Reply #26 on: September 12, 2012, 11:18:49 am »
The TDI injectors are dual stage.  How are you setting the main injection event (which is more important than the pilot one)?
Reply #27September 12, 2012, 12:14:46 pm
JFettig
  • 82
« Reply #27 on: September 12, 2012, 12:14:46 pm »
I'm making a special tool. It took some reverse engineering but I'm 99% sure I have it figured out. I probably shouldn't post any details publicly.
not reverse engineering - I'm not stealing someones design :)
« Last Edit: September 12, 2012, 12:23:17 pm by JFettig »
Reply #28September 12, 2012, 06:59:17 pm
JFettig
  • 82
« Reply #28 on: September 12, 2012, 06:59:17 pm »
Made a craigslist score today, Hartridge POPTEST-3!
might keep both, will post my own thread later.
« Last Edit: September 17, 2012, 06:29:10 am by JFettig »
