Author Topic: 1990 1.6TD engine partout  (Read 3900 times)
August 17, 2012, 07:09:53 am
« on: August 17, 2012, 07:09:53 am »
Pictures are coming later
I think the KMs are around 300k kms but I will double check that. The engine was running fine
TD pump - Appears dry and in good shape, $sold
Exhaust Manifold - $sold
Intake Manifold - missing nuts and top heat shield, bolts to mount to head included - $sold
Downpipe - Hole in it, would need to be patched or just use the flange to make your own - $sold
T3 Turbo - Good shape, normal amount of up and down, 0 in and out - Mounting bolts included, leaky rotten oil drain line included if desired - sold
I have the rest of the engine available, these are just the parts I have removed. Ask if you want something that's not listed. Engine has AC and PS
Will ship to wherever.
« Last Edit: August 29, 2012, 10:07:58 am by burn_your_money »
Reply #1August 17, 2012, 07:35:47 am
bbob203
  • 1789
Re: 1990 1.6TD engine partout
« Reply #1 on: August 17, 2012, 07:35:47 am »
how much for rest of engine?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 17, 2012, 07:40:18 am
« Reply #2 on: August 17, 2012, 07:40:18 am »
I want to pull the head first, it might be warped. I bought it with no coolant because the metal line burst. PO said he didn't drive it like that but who knows. It started right up and reved nicely though so it should be fine. You can take the block and head for $100 as-is and take your chances I suppose
Reply #3August 28, 2012, 05:12:26 pm
dl_sledding
  • 48
« Reply #3 on: August 28, 2012, 05:12:26 pm »
Burn, you still got the block and head???  Willing to ship?
Reply #4August 28, 2012, 06:20:49 pm
« Reply #4 on: August 28, 2012, 06:20:49 pm »
Yes, IM sent
