Author Topic: Re: Gear Selector Problems, NOW FIXED......  (Read 4048 times)
August 14, 2012, 02:15:21 pm
james277553
  • 27
« on: August 14, 2012, 02:15:21 pm »
So tonight I'm driving home from work thinking how well my car is going and suddenly out of no where I find I can't select my gears very well, It got worse and worse during the rest of my journey. When I get home I realise this bolt in picture below had worked loose!!. :o
I unscrewed the bolt and noticed the end was missing the little ball bearing.
Does anyone know what this part does and if i may have damaged my gearbox beyond repair. I need to source this part and unsure what it is called.
I have all new bush's and rod's so know that is not to blame for poor gear selection. Hope someone can help. Thanks
« Last Edit: August 18, 2012, 07:54:40 am by james277553 »
Mk2 Golf sb 1.6 GTD. Gov mod, Uprated intercooler. Loads more.
Reply #1August 14, 2012, 02:32:05 pm
Re: Gear Selector Problems, can you HELP identifying this part.....
« Reply #1 on: August 14, 2012, 02:32:05 pm »
thats the detent for the shifter assy..
Reply #2August 14, 2012, 02:42:35 pm
james277553
  • 27
« Reply #2 on: August 14, 2012, 02:42:35 pm »
That's the one thanks.
Looks like a common problem with them falling apart, lets just hope it didn't bugger my gears. will have a look tomorrow see if I can find the part I need. Found this site interesting read:  http://www.brokevw.com/5detent.html
Reply #3August 18, 2012, 07:53:55 am
james277553
  • 27
« Reply #3 on: August 18, 2012, 07:53:55 am »
Well today I finally got the new part from the VW Stealership. It cost me £17 for a fancy bolt! :o But as you can see from the picture the original was absolutely knackered. I had to use a magnet and remove the bearing separately, Its no wonder I struggled to get home.
I fitted the new part in seconds and my gearbox is better than ever now. It was pretty good after replacing all the bushes last year but now with this installed its like new. ;D
I would recommend people checking this if there having problems getting gears smoothly.
Hope this is some help to a few people.
