Author Topic: 1.6td injector pump timing help--Anchorage AK  (Read 4210 times)
August 14, 2012, 10:01:46 am
gitkrunk
  • 31
« on: August 14, 2012, 10:01:46 am »
anyone in town willing to help? i got cash for your troubles
Reply #1August 14, 2012, 10:26:23 am
JessaBug
  • 112
Re: 1.6td injector pump timing help--Anchorage AK
« Reply #1 on: August 14, 2012, 10:26:23 am »
Can you elaborate? Do you not know how to set the timing? Are you running into problems?
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #2August 14, 2012, 02:29:53 pm
gitkrunk
  • 31
« Reply #2 on: August 14, 2012, 02:29:53 pm »
i timed the timing belt and it all rotates smooth. now im timing the pump to the 1mm. was justing looking for a second set of hands to make sure i did it right... first vw and diesel
Reply #3August 15, 2012, 06:39:05 am
JessaBug
  • 112
« Reply #3 on: August 15, 2012, 06:39:05 am »
His - '01 Jetta TDI
Reply #4August 15, 2012, 07:43:04 am
bbob203
  • 1789
« Reply #4 on: August 15, 2012, 07:43:04 am »
as long as you know the timing belt is on correctly ie all the marks line up with cyl 1 at top dead center loosen the ip bolts but keep them snug enough to where you can still moved it with some elbow and fire the car up and rotate toward engine until it clacks like hell then back it off just to the point before clackage begins.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
