Author Topic: 1988 Jetta 1.6TD, bone stock!  (Read 25245 times)
Reply #45January 05, 2013, 08:43:58 am
Re: 1988 Jetta 1.6TD, bone stock!
« Reply #45 on: January 05, 2013, 08:43:58 am »
Does it still have the sequential blinkers. Is yours a 289?
All original sequential system, fully operational. :D If it were factory it would be a 289, 3 on the floor. I dunno if the picture conveys it, but those big fender flares on the back hide a near 12" drag radial.
It is probably the furthest thing from a numbers car.. LOL The drive train is pretty much an entire setup from an '87 F150, including the AOD 4 speed auto. It is a 5.0L H.O, forged internal, roller motor with the best OEM heads on the market available in the 80's, ET7E to be exact ;). The beast breathes through a 650 Holley Quad, down in to a Edelbrock Performer RPM, out through some big primary long tube headers, and finally dumps from some cherry bombs before the rear axle, which I am to believe is a 3.00 or a 3.50.. ??
It runs a stock ignition system, so I guess that should be my next upgrade.. although it doesn't really give any trouble.
I wish my Volkswagen had this clean of a setup! lol
« Last Edit: January 05, 2013, 08:48:02 am by 8v-of-fury »
Reply #46January 05, 2013, 10:48:44 am
« Reply #46 on: January 05, 2013, 10:48:44 am »
Nice!
What is with the fuel line going through the upper shock mount?
Reply #47January 05, 2013, 03:36:01 pm
« Reply #47 on: January 05, 2013, 03:36:01 pm »
Nice!
Unhooked from the fuel line, its in winter storage. So I drain the tank and lines. Also why the battery cables are undone lol.
Reply #48January 05, 2013, 08:11:32 pm
« Reply #48 on: January 05, 2013, 08:11:32 pm »
Glad that you pointed out why it was like that. After all you are the fuel specialist. Restored my faith in you.
Reply #49January 06, 2013, 06:32:14 pm
« Reply #49 on: January 06, 2013, 06:32:14 pm »
She smokes a little bit right after a cold start, but not a stumble to be heard.
Reply #50March 08, 2013, 11:51:41 am
« Reply #50 on: March 08, 2013, 11:51:41 am »
This blue spot is the cars only flaw...
Came with chains!! COOL. Didn't need them, even when we got dumped on by 16" of thick snow. This thing walked through it
Because I had these on it ;) hjaha
Reply #51March 08, 2013, 01:58:02 pm
« Reply #51 on: March 08, 2013, 01:58:02 pm »
If that blue spot is spray paint, it will come off and not hurt a factory finish underneath. I will let you know if you are interested. If there is something under it that they were covering then it is a different story.
Reply #52March 08, 2013, 02:46:52 pm
« Reply #52 on: March 08, 2013, 02:46:52 pm »
Some dick in a parking lot.. not covering a thing. Whats the word? I was thinking of just some like 1500 sandpaper wet sand
Reply #53March 09, 2013, 07:56:06 am
gtiguy1994
  • 67
« Reply #53 on: March 09, 2013, 07:56:06 am »
Nice car! I enjoy seeing threads like this  :)
World Rally Championship!
Reply #54March 09, 2013, 09:07:46 am
« Reply #54 on: March 09, 2013, 09:07:46 am »
1500 wet paper might do the trick, Jeremy.
I would me inclined to use some polishing or rubbing compound first.
Reply #55March 10, 2013, 09:36:19 pm
JamesT
  • 151
« Reply #55 on: March 10, 2013, 09:36:19 pm »
I would try oven cleaner before sanding. There's a good chance you can get the blue off without hurting the clear at all. Just apply and scrub off every 10 minutes until it's gone. Should take two or three applications.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #56March 10, 2013, 09:39:04 pm
« Reply #56 on: March 10, 2013, 09:39:04 pm »
compound, ah.. never crossed my mind haha.
oven cleaner might do the trick too..
I have heard brake cleaner.. as well.
Reply #57March 11, 2013, 02:55:13 pm
« Reply #57 on: March 11, 2013, 02:55:13 pm »
U might be surprised how easy that comes off
Reply #58March 15, 2013, 06:17:49 am
« Reply #58 on: March 15, 2013, 06:17:49 am »
I really would just start with an ordinary polishing compound and powered polisher with a foam wheel.  It'll either get really shiny or just come right off.  You can do the rest of the car while you're at it! ;)
