Author Topic: Garage cleaning, 1.6, 1.9 AAZ, 1.9 1z/ahu parts + car parts mk2,3,4,b3,b4  (Read 6174 times)
August 13, 2012, 09:22:03 am
houseofdiesel
  • 210
I am finally getting inside the garage again, stuff is going and some will likely be recycled. Here is a SMALL example of what I have stumbled on recently as I packed for the recent VW show here, more to come. MOST PARTS are a buck or two, I have no use for it anymore. I will reply when I have time I am raising two young kids. I am only listing what is readily found...garage sale pricing promised! Pics to identify parts are no problem.
1.6 intake manifolds
1.6 non a/c accessory bracket (cast iron for alternator)
1.6 accessory pulleys, many sizes
engine mount brackets
alternators, mostly cores
starters in parts only
1.6 turbo oil feed line
valve covers
plastic upper timing belt covers
metal inner timing belt covers
various engine hardware-all metal parts that bolt on
used glow plugs tested
injector cores (40+, some VW, some Mercedes, some Audi, some Volvo etc)
Crank pulleys
Cam and intermdiate shaft pulleys
1.9 aaz k03 turbo in parts (broken center shaft), not terribly rusty
1.9 AHU turbo Garrett GT15 two for parts, one rebuilt unsuccessfully (noise, no play and not burning oil) one shaft play and seized waste gate
1.9 ALH Garrett VNT 15 turbos three in parts all disassembled already
mk2
All interior parts, everything plastic, moslty in black only-window cranks, lock knobs, door handles/trim, carpet hold downs, door sills, speaker grills, pretty much every part was kept to replace any missing pieces that I might need to fix up a car to sell. There are two laundry baskets full
Rear coil springs, rear spring perches. Door handles and latches and all trim milk crate full
Passat B3 seats, wagon rear doors, mirror left side, grill, bumper, front struts complete with recent Monroes and coil springs/mounts, headlights, turn signal lights,
mk3 coil springs front and rear
mk4 front coil springs, headlight switch, radio
Passat B4 series tdi-a bit more valuable to me
parts sedan and wagon, stripped 4 lately. Doors, bumpers, hood, hatch, trunk, headlights, trailights, bumper lights, grills, interior trim, seats, rads, fans, engine cross member, hoses, a/c parts, wiring, flywheels, wiper arms, power windows
vr6 used coil pack, used secondary air pump and hose, new crack pipe for cooling system and thermostat cover, factory spark plug wire puller.
Once I make some space to actually walk inside the garage I will make it to the second floor, there is the rare stuff like Audi 2.0 td 5 cylinder and Volvo 2.4 td 6 cyl parts and old Mercedes. I also have a complete 98 Jetta tdi and two 97 Passat sedans whose fate is undecided yet so YES I have the parts...
Reply #1August 19, 2012, 10:23:18 pm
southernman
  • 72
HOD, I've got an '82 Caddy 1.6 na pickup and the rear drum brakes appear to be of the smaller size. They are the 211mm drums, but I understand the Caddy's had larger 240mm drums on them. I'm thinking the stub axles may have went bad years ago on this truck and someone just bolted up the Rabbit brakes just to get the thing running.
Anyway, I'm in the process of rebuilding the brakes on this truck and am trying to locate the larger 240mm assy's. Preferrably everything from the stub axles out, which would simplify installation for me.
Got any such parts ?
Dave, Raleigh NC (27613)
'82 VW Caddy w/ 1.6 NA Diesel - completely stock.
Reply #2September 19, 2012, 07:58:52 am
madrogers
  • 165
Re: Garage cleaning, 1.6, 1.9 AAZ, 1.9 1z/ahu parts + car parts mk2,3,4,b3,b4
« Reply #2 on: September 19, 2012, 07:58:52 am »
looking for a mk 1 r/s diesel engine mount/ braket , would you have something like that in your pile of goodies.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #3September 19, 2012, 04:21:23 pm
  • 1739
« Reply #3 on: September 19, 2012, 04:21:23 pm »
I may need a Canadian instrument cluster for a TDI passat. I will know in a few minutes. If you have , how much?
Reply #4September 20, 2012, 07:32:09 pm
camboscams
  • 324
« Reply #4 on: September 20, 2012, 07:32:09 pm »
How much for the vnt's? One or all?
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #5September 21, 2012, 06:53:09 am
vwsb1974
  • 81
« Reply #5 on: September 21, 2012, 06:53:09 am »
 I need a mk2 jetta 4 door drivers side front door mirror trim piece the black triangle on the inside I also need trunk carpet
Reply #6September 21, 2012, 07:57:40 am
xxkoadyxx
  • 179
« Reply #6 on: September 21, 2012, 07:57:40 am »
Hey man, I'm looking for a engine wiring harness for the TDI, last one I bought I only got half the harness. Also I am looking for a mk3 tdi DBW pedal.
Lmk what your prices are, if your willing to ship to B0K1S0 stellarton, nova scotia.
Thanks!
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #7September 21, 2012, 08:25:16 am
starrd
  • 128
« Reply #7 on: September 21, 2012, 08:25:16 am »
I am looking for 4 VW 1.6 TD injector cores.  Can you let me know via PM please.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #8September 24, 2012, 10:34:48 am
Trips_B
  • 57
« Reply #8 on: September 24, 2012, 10:34:48 am »
Hey, looking for a 1.6td intake mani and 4 black windoes cranks
Reply #9October 01, 2012, 07:01:03 am
houseofdiesel
  • 210
Kids kept me offline lately...
trips_b have lots of window cranks and 1.6 manifold td $20 plus shipping cost
starrd pm replied again lots of cores $10 plus shipping for a set of 4
xxkoadyxx I do have complete harness and pedal will pm with costs/shipping etc
vwsb1974 probably have the trim but no carpet
camboscams have two VNTs in parts, one complete but shipping will likely outweight the costs! Let me know what you want
NO mk1 parts left that I am aware of, certainly no caddy parts never had one.
Reply #10October 02, 2012, 07:06:10 am
« Reply #10 on: October 02, 2012, 07:06:10 am »
Looking for an AAZ rear engine mount bracket (the bracket itself, not the rubber mount)
Reply #11October 07, 2012, 08:55:58 pm
92EcoDiesel Jetta
« Reply #11 on: October 07, 2012, 08:55:58 pm »
I have one, passenger side. PM me
