Author Topic: Source for AAZ/TDI K03 Turbo Outlet Flange  (Read 11442 times)
August 13, 2012, 07:47:41 am
« on: August 13, 2012, 07:47:41 am »
Anyone know where I can buy a turbo outlet flange for an AAZ/AHU/1Z/AFN K03 turbo?
Reply #1August 13, 2012, 08:03:04 am
Re: Source for AAZ/TDI K03 Turbo Outlet Flange
« Reply #1 on: August 13, 2012, 08:03:04 am »
When vdubspeed put one of those on his 1.6 he couldn't find it and ended up just buying the prothe down pipe and modifying it.  Which may just be ur best bet, despite the qualms many have about prothe
Reply #2August 13, 2012, 08:06:36 am
Reply #3August 13, 2012, 11:38:10 am
« Reply #3 on: August 13, 2012, 11:38:10 am »
034motorsport has a lot of flanges, but they don't appear to have the VW AAZ/TDI K03 turbo outlet flange.
Reply #4August 13, 2012, 12:00:15 pm
« Reply #4 on: August 13, 2012, 12:00:15 pm »
x2...
Vdubspeed looked ALOT, and looked hard..
never found a better flange than the prothe downpipe..
i know how we all love prothe, but if he is the only one offering something, then what other options do you have?
one solution, would be to find a shop with a torch-mate, and CAD one up..
i cut all my VNT flanges on the torch-mate in class..
my welding instructor loved it when i would work on my own projects in class, rather than just weld pieces of steel together for practice.
Reply #5August 13, 2012, 02:44:02 pm
slowcaddydan
  • 20
« Reply #5 on: August 13, 2012, 02:44:02 pm »
I have an AAZ/KO3 downpipe in my garage.  It's not for sale but I can take pictures and measurements if anyone wants them.
Reply #6August 13, 2012, 08:00:40 pm
« Reply #6 on: August 13, 2012, 08:00:40 pm »
ill ask.. is not aaz top mounted where tdi is bottom mounted? aaz would be same as say a older t3 style 4 bolt one?
for my stock 98 jetta tdi turbo i got a piece of plate steel... used a torch to shape it... added big hole in middle.. as big as i could to not be out side of the turbo castin.. almost 2.5" but not quite.. kinda square in design.. used the gasket to make the pattern...
i picked up a t3 style stainless flange in 2.5" for 20ish from amazon.. one day ill get one fo rmy project.. but for now the flange hangs on my wall.. with v bands waiting to build..
Reply #7August 13, 2012, 10:04:12 pm
« Reply #7 on: August 13, 2012, 10:04:12 pm »
The K03 outlet flange is the same for the AAZ or TDI.  The difference in the manifolds causes the turbo to be rotated differently, but the flange is the same.  Neither K03 has a square flange.
Reply #8August 14, 2012, 09:31:00 am
slowcaddydan
  • 20
« Reply #8 on: August 14, 2012, 09:31:00 am »
on my AAZ/KO3 the manifold to turbo flange is a triangle with 3 bolts.  the turbo to downpipe is 4 bolts and somewhat square. if i remember correctly (engine is out of car), it points towards the driver side???
Reply #9August 14, 2012, 10:06:47 pm
Powered by Spearco
  • 1203
« Reply #9 on: August 14, 2012, 10:06:47 pm »
Ya might want to try Techtonics Tuning here in Oregon. Ask to talk with Josh. He might be able to help you out with a flange.
http://techtonicstuning.com/main/index.php?main_page=index&cPath=2_11_4_284
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10August 17, 2012, 07:34:36 pm
commuter boy
  • 277
Reply #11August 17, 2012, 08:00:50 pm
« Reply #11 on: August 17, 2012, 08:00:50 pm »
that looks like it...but i cannot beleive libby lacks oxy/acetilin torch set up.. or has no access to one... piece of plate steel... cut w/torch... smooth w die grinder/file... drill press for holes..
Reply #12August 17, 2012, 08:55:09 pm
« Reply #12 on: August 17, 2012, 08:55:09 pm »
I have the capacity and have made quite a few flanges.  If I can find one for $20-30 tho, it's not really worth my time.  Despite all that, this thread was on behalf of a friend of mine who lives in New Mexico.
Reply #13August 18, 2012, 04:07:40 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #13 on: August 18, 2012, 04:07:40 am »
lasercutting is the best option by far - its cheap and easy. if you can cad one up, you can find a lasercutter who will cut it for you. They usually take dxf's.
'91 Golf Cabrio 1.9TD
Reply #14August 18, 2012, 05:20:47 am
BlueMule
  • 51
« Reply #14 on: August 18, 2012, 05:20:47 am »
Libby, how bou't this, I'm more familiar with numbers like 14-71 rather than K03, just thinking the K and T outlets might be the same?
http://stainless.eclipticcms.com/turboflanges
Blau Maultier
BlueMule
A.S.E. Master Since 1986
Nissan Master Since 1995
Auto Tech Since 1975
Totally Ignorant When It Comes To MY
'86 Golf TD
