Author Topic: Where to obtain 85 TD radiator fan ceramic resistor?  (Read 5172 times)
August 12, 2012, 11:21:09 am
Dakotakid
  • 1240
« on: August 12, 2012, 11:21:09 am »
Wantng to obtain one of the ceramic-style (about 2.5 inches long or so) radiator fan (low speed) resistors for an '85 Jetta TD mobile. This is found on the radiator shroud and clips between the steel holders.
Anyone with used one? Where to buy new if needed. What can I use as a substitute from the general population?
I used to have stuff like this and threw much of it away when I left the farm.....sheet.
Reply #1August 12, 2012, 11:30:15 am
bbob203
  • 1789
Re: Where to obtain 85 TD radiator fan ceramic resistor?
« Reply #1 on: August 12, 2012, 11:30:15 am »
I need one of these as well.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 12, 2012, 12:23:30 pm
« Reply #2 on: August 12, 2012, 12:23:30 pm »
might use one from a Jeep Cherokee..
i know they use one as well, and its still available..
Reply #3August 12, 2012, 02:17:14 pm
« Reply #3 on: August 12, 2012, 02:17:14 pm »
update to 86 style 2 speed stuff/wiring... no resistor.. they use relays..
Reply #4August 12, 2012, 02:26:49 pm
bbob203
  • 1789
« Reply #4 on: August 12, 2012, 02:26:49 pm »
my 91 has the reisitor still.
03 Jetta wagon TDi
Reply #5August 12, 2012, 08:00:01 pm
« Reply #5 on: August 12, 2012, 08:00:01 pm »
the TDs/ECOdiesel had 3 spd fans..
they are way different..
gas, and n/a are all different..
Reply #6August 12, 2012, 08:14:43 pm
Dakotakid
  • 1240
« Reply #6 on: August 12, 2012, 08:14:43 pm »
Some days I consider shoehorning a little Briggs and Stratton in some Schwinn frame and calling it good....................
Reply #7August 12, 2012, 08:25:25 pm
« Reply #7 on: August 12, 2012, 08:25:25 pm »
86+ gas & n/a use ONE relay..
the low speed side of the fan is run DIRECTLY thru the fan switch..
only the HIGH SPEED side of things are on a relay..
Reply #8August 12, 2012, 08:43:48 pm
« Reply #8 on: August 12, 2012, 08:43:48 pm »
HAH! I am doing this right now! A Tecumseth though, and not a Schwinn.. lol
Reply #9August 13, 2012, 10:33:37 am
Dakotakid
  • 1240
« Reply #9 on: August 13, 2012, 10:33:37 am »
If you get it running, buy yourself a little grey suit with a red bow tie, with white socks and ride around on it (a la Peewee Herman)! Just don't go into the adult theatres.
Reply #10August 13, 2012, 11:50:15 pm
mystery3
  • 774
« Reply #10 on: August 13, 2012, 11:50:15 pm »
I'm afraid about %90 of the users on this site are too young to get this reference and at least %5 are too old, but I gotcha, and now have "tequila!" stuck in my head thanks.
Reply #11August 14, 2012, 07:06:01 am
« Reply #11 on: August 14, 2012, 07:06:01 am »
I am with you.
Reply #12September 16, 2012, 07:48:19 pm
bbob203
  • 1789
« Reply #12 on: September 16, 2012, 07:48:19 pm »
did you ever obtain one of these?
03 Jetta wagon TDi
Reply #13September 16, 2012, 09:09:38 pm
Dakotakid
  • 1240
« Reply #13 on: September 16, 2012, 09:09:38 pm »
No mon.....
