Author Topic: Any hints on separating the tierod from the spindle?  (Read 5783 times)
August 12, 2012, 12:04:13 am
mtnbob
  • 738
« on: August 12, 2012, 12:04:13 am »
I need to adjust my steering and I prematurely tightened my tierods down before I checked them. Now I can't seem to get them apart. Any ideas? Bigger sledgehammer???? ;D
96 Subaru Outback Wagon
Reply #1August 12, 2012, 12:50:42 am
Re: Any hints on separating the tierod from the spindle?
« Reply #1 on: August 12, 2012, 12:50:42 am »
loosen lock nut on tie rod... turn tie rod???
remove lock nut from spindle.. hit spindle on its edge where it goes thru with hammer till pops..
Reply #2August 12, 2012, 02:42:43 am
bbob203
  • 1789
« Reply #2 on: August 12, 2012, 02:42:43 am »
you don't need to take it off to adjust it just use a wrench and turn the hexed part of the tie rod left or right in order to adjust the toe. did you install a manual rack in place of p/s?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3August 12, 2012, 06:40:03 am
« Reply #3 on: August 12, 2012, 06:40:03 am »
that was choice #1.. :P
Reply #4August 12, 2012, 08:25:43 am
mtnbob
  • 738
« Reply #4 on: August 12, 2012, 08:25:43 am »
yes it is a manual steering rack. I am just having trouble getting it to release from spindle so I can turn it.
Reply #5August 12, 2012, 08:28:47 am
« Reply #5 on: August 12, 2012, 08:28:47 am »
loosen lock nut on tierod to tie rod end.. turn rod...
Reply #6August 12, 2012, 09:11:15 am
mtnbob
  • 738
« Reply #6 on: August 12, 2012, 09:11:15 am »
It won't turn when still attached to the spindle though ???
Reply #7August 12, 2012, 10:27:34 am
« Reply #7 on: August 12, 2012, 10:27:34 am »
Turn the other piece.
Reply #8August 12, 2012, 12:24:42 pm
« Reply #8 on: August 12, 2012, 12:24:42 pm »
turn the TIE ROD.. not the tie rod end..
Reply #9August 12, 2012, 01:19:13 pm
bbob203
  • 1789
« Reply #9 on: August 12, 2012, 01:19:13 pm »
there should be a hexed section to use a 14mm wrench to turn it.
03 Jetta wagon TDi
Reply #10August 12, 2012, 04:37:21 pm
mtnbob
  • 738
« Reply #10 on: August 12, 2012, 04:37:21 pm »
TY  I got this issue straightened out. Now on to the clutch!!!!!
Reply #11August 12, 2012, 05:23:44 pm
bbob203
  • 1789
« Reply #11 on: August 12, 2012, 05:23:44 pm »
manual cable!
03 Jetta wagon TDi
Reply #12August 12, 2012, 05:46:04 pm
mtnbob
  • 738
« Reply #12 on: August 12, 2012, 05:46:04 pm »
I am not getting any resistance on the clutch pedal :( I was hoping it would be smoother since I replaced the clutch and throw out bearing, but the only resistance is the spring. Not feeling any clutch resistance at all.
Just when I thought it was going well
