Author Topic: What's up with this? Refillable strut?  (Read 5299 times)
August 09, 2012, 10:59:08 am
« on: August 09, 2012, 10:59:08 am »
So I swapped to monroe struts on my '92 german golf a couple months ago and today decided to see if my old ones the type that take inserts so I could keep the housings. Sure enough, there's a big external nut on top so I undo it and yank the insert out......only it's not an insert. It's the internals of the damping mechanism.
Oil ran everywhere and there's pistons with o-rings and stuff. Never heard of this style. Any info?
Thanks
Reply #1August 09, 2012, 01:00:23 pm
Re: What's up with this? Refillable strut?
« Reply #1 on: August 09, 2012, 01:00:23 pm »
mmmmmm hmmm ummmm mmmm goood.... the smell of that oil sticks with you too... factory... original...
Reply #2August 09, 2012, 01:36:33 pm
« Reply #2 on: August 09, 2012, 01:36:33 pm »
It's probly not refillable with any lifespan though?
Reply #3August 10, 2012, 08:31:33 pm
  • 2931
« Reply #3 on: August 10, 2012, 08:31:33 pm »
I saw that with an earlier Jetta.
 Probably could be rebuilt if anyone knew how,.. old technology.
Reply #4August 10, 2012, 08:33:18 pm
« Reply #4 on: August 10, 2012, 08:33:18 pm »
But Why? Its a time of Replace>Fix.
Reply #5August 11, 2012, 04:15:41 pm
rs899
  • 647
« Reply #5 on: August 11, 2012, 04:15:41 pm »
Yup, thats an original strut.  If you can find inserts, you are golden.  The inserts include an external tube that fit \s inside so your old tube/body can be reused.
Reply #6August 21, 2012, 11:06:52 pm
« Reply #6 on: August 21, 2012, 11:06:52 pm »
Ever notice how short a life span replacement parts usually have? I like original.
I've never seen that and I've looked at replacement stuff online a LOT.
Reply #7August 21, 2012, 11:20:15 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #7 on: August 21, 2012, 11:20:15 pm »
GAP sell inserts for mk1 front shocks.
sorry, just re-read you said 92.... hmm I dont know.
here ya go
http://www.germanautoparts.com/Volkswagen/Golf/Suspension/188
« Last Edit: August 21, 2012, 11:23:05 pm by gldgti »
'91 Golf Cabrio 1.9TD
Reply #8August 22, 2012, 07:33:29 am
« Reply #8 on: August 22, 2012, 07:33:29 am »
Unless it was made 15 years ago, its the same quality as every other replacement part out there ;) Even if it is an OEM brand. You are fixing your strut housing with a replacement insert, the housing surely will never stop doing its job unless damaged.
Reply #9August 23, 2012, 11:50:44 am
« Reply #9 on: August 23, 2012, 11:50:44 am »
well I've heard of inserts, I thought there was some sort of sleeve used to put an insert into this housing.........
Reply #10August 23, 2012, 05:31:06 pm
rs899
  • 647
« Reply #10 on: August 23, 2012, 05:31:06 pm »
I recently bought a pair of Monroe SensaTrac inserts for my Cabriolet from Rock Auto for $13 each.  When I saw they were made in Belgium  I bought another pair for my pickup.  I like picking off their closeouts because they tend to be NOS stuff.  How about MOOG(USA) geaseable Mk1 tie rod ends for $5?
