Author Topic: Scored Piston and barrel - 1.9 AAZ Vanagon  (Read 6366 times)
August 04, 2012, 03:38:43 pm
Gizmoman
  • 1301
« on: August 04, 2012, 03:38:43 pm »
I am rebuilding my 1.9 due to what appeared to be a blown HG - never saw positive sign of that but I did have a loose pre-cup on # three and the others were a bit loose as well.
Today I got into the bottom end and pulled the pistons. All look quite good with the exception of #4.
Both the barrel and the piston are scored :'(.
The bore is stock 79.51mm and all other barrels look good (however, if there were ever hone marks, they are gone) but #4 is scored down both sides (front and back) and I doubt a hone would clean it up. The top ring on #4 piston is sorta jammed into the groove. My guess this thing just got a bit too hot? What else could have caused this?
Some of the scoring actually may be some aluminum from the piston and if I were to hone it, that would go away. In other words, possibly honing is worth a try.
If anyone knows of a good shop here in San Diego, please let me know. Also, any recommendations on high quality rings and pistons would help.
Thanks
Reply #1August 04, 2012, 05:29:48 pm
Jarrus
  • 17
Re: Scored Piston and barrel - 1.9 AAZ Vanagon
« Reply #1 on: August 04, 2012, 05:29:48 pm »
Maybe lack of lubrication in a previous life?
Reply #2August 05, 2012, 06:27:10 am
« Reply #2 on: August 05, 2012, 06:27:10 am »
I would say this is further evidence that it was ran really hot, high egt's. The precups don't come loose with out that heat and it looks like the piston grew too much for its bore. If it has been ran like this I would recommend the shop taking a look at it.
Reply #3August 05, 2012, 07:36:03 am
Gizmoman
  • 1301
« Reply #3 on: August 05, 2012, 07:36:03 am »
Yeah, I agree, defiantly got toasty in there!
I'm wondering if a plugged oil squirter on 4 could cause this as it's only #4 - the other 3 look just dandy - I would think 2&3 would be the first to go. Any thoughts?
You'd think I would have know better turning up the fuel and boost with no IC or EGT - well, I know now :)
Reply #4August 05, 2012, 08:05:21 am
« Reply #4 on: August 05, 2012, 08:05:21 am »
It is a possibility that the oil squirter was messed up, but IIRC they usually stick open not closed. Not sure on that one.
Another idea is that #4 fuel injector could have been messed up. Bad atomization causing hot spots.
Reply #5August 05, 2012, 08:47:41 am
Gizmoman
  • 1301
« Reply #5 on: August 05, 2012, 08:47:41 am »
Ok, That makes sense (you usually do  ;D)
While I'm putting my list of needed parts together I am also going through the K14. In the FAQ, there's tons of great info and a lot of it is from you. In particular, I need to remove the waste gate (customized an Allen wrench already) and I have it loose.
Getting it out though seems impossible. The post in the FAQ says
So following Andy2's advice, I slide hammered those heat shields out of there! Here is what it looked like when they came out... lots of carbon built up:
Does he mean he used the waste gate housing as a slide hammer? Should I heat the housing up? This thing is really stuck - looks like " the heat shield is part of the casting.
Any advice appreciated.
Reply #6August 05, 2012, 08:52:30 am
« Reply #6 on: August 05, 2012, 08:52:30 am »
I did that and used the wastegate housing as a slide hammer. For the time and hassle involved send it to those guys in Ohio that rebuild the turbo for 225.00
Reply #7August 05, 2012, 09:00:56 am
Gizmoman
  • 1301
« Reply #7 on: August 05, 2012, 09:00:56 am »
Right after I asked, I went back and got after it - came right out after about six "hammers".
Defiantly couldn't have been seating too well on that bet of carbon.
I'll take your advice about sending it out. Hope they don't charge extra for getting a box-o-bits :)
Reply #8August 05, 2012, 09:57:05 am
« Reply #8 on: August 05, 2012, 09:57:05 am »
Another possibility is that the exhaust or intake valve on that cylinder leaked and let out the boost air.  The resulting over-fueled situation got the piston too hot and it started to melt.  That would be pretty easy to check.  Tip the head on it's side with the ports up and pour/spray some solvent in there.  If it leaks out on the combustion face, your valves were leaking.  Any impressions on the piston tops?
Reply #9August 05, 2012, 01:52:34 pm
Gizmoman
  • 1301
« Reply #9 on: August 05, 2012, 01:52:34 pm »
OK, I did the leak test and it appears to be bleeding a bit out around both valves. As to "impressions on the piston tops" - I did notice some fairly large chunks - yes chunks of carbon in the intake ports. Some of this stuff is quite hard and there are some tiny marks on top of the piston near the edge. It actually looks like a few bits of carbon broke loose and may have gotten in there (as if could go anywhere else :)). The piston sides look like someone tossed in a few large grains of sand. Could bits of carbon do this and why would I have carbon on the intake ports anyhoo?
I 'spoze from leaky valves?
Right now the carbon is crusty but not as hard as sand. I wonder though what i's like when it's really really hot.
« Last Edit: August 05, 2012, 02:02:27 pm by Gizmoman »
Reply #10August 06, 2012, 07:34:35 pm
Gizmoman
  • 1301
« Reply #10 on: August 06, 2012, 07:34:35 pm »
I think I found a decent local machine shop to do the block boring. They say they specialize in Diesel engines.
Before I take it in to them, what would be a decent price to expect to have them just bore all four barrels to one size over from stock.
Any advise on what I should ask about - special things to consider, etc?
I am also looking at Hans pistons. I've heard they are pretty good but that I should get rings somewhere else. Any suggestions?
Thanks
Reply #11August 06, 2012, 07:54:17 pm
CrazyAndy
  • 739
« Reply #11 on: August 06, 2012, 07:54:17 pm »
AS far as the machinist price, I can't help you there.  Prices do vary moderately, though.
As for Hans (aka Prothe) pistons, yes you can use the pistons but don't use the rings.  Too many folks have reported excessive consumption post-break in.  Stop by your local NAPA and order some OS Goetze's.
Reply #12August 06, 2012, 11:14:34 pm
Gizmoman
  • 1301
« Reply #12 on: August 06, 2012, 11:14:34 pm »
Thanks Crazyandy - much appreciated. His pistons look 1st class in the photos and with what appears to be an anti-friction coating on the skirts. I noticed on the Goetze website they make metal head gaskets as well probably spendy but a wise investment.
Reply #13August 07, 2012, 05:39:55 am
« Reply #13 on: August 07, 2012, 05:39:55 am »
Just remember that "specializing in diesel" doesn't mean they know about these engines. My last machinist did reluctanly bore to the .001" size bigger than the piston. But he didn't want to as he said most diesels were bored to around .003"...that is the wear limit of our engines. I would check out the bently and ask them many questions about what their plans are to do, if you know what is expected then you will know what you need to hear. If they argue and won't do it as the bentley says then leave and find one who will. Also have your pistons in hand when boring, I wouldn't trust a shop that didn't bore to the piston and just went with a .020" over stock as some pistons measure differently.
Reply #14August 07, 2012, 05:07:04 pm
Gizmoman
  • 1301
« Reply #14 on: August 07, 2012, 05:07:04 pm »
Excellent advice theman53, will do.
After doing a search on Gotze rings, I found some very unhappy guys who get wide ring gaps using them - even after several attempts. One poster said he goes one size over and files them to the proper gap.
I believe you have been involved in several of these discussions as well. What is your opinion?
« Last Edit: August 07, 2012, 05:09:42 pm by Gizmoman »
