Author Topic: setting idle  (Read 2136 times)
August 02, 2012, 10:02:19 am
vwsb1974
  • 81
setting idle
« on: August 02, 2012, 10:02:19 am »
I have serched for this and did not find what i was looking for. My question is how do i check the engine speed. I know how to change it I just want to know how to check it? There is no signal for a timing light so how do you check it? I know you would check it on the timing spot on the trans. I am adding a TAC and want to make it as accurate as i can.
Reply #1August 02, 2012, 02:31:02 pm
Re: setting idle
« Reply #1 on: August 02, 2012, 02:31:02 pm »
I use a diesel pulse adapter and timing light with rpm function.
Reply #2August 02, 2012, 08:57:59 pm
VW_Commuter
  • 355
Re: setting idle
« Reply #2 on: August 02, 2012, 08:57:59 pm »
Look around for a phototach.  All you do then is to put some reflective tape on the pulley of your IP and use the phototach to get the RPM of the pump.  RPM of engine = RPM of pump x2.  Or, you can put 2 pieces of the reflective tape on the pulley, 180 degrees apart and then the RPM read on the phototach will be the RPM of the engine.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #3August 03, 2012, 02:06:40 am
CarlosA
  • 139
Re: setting idle
« Reply #3 on: August 03, 2012, 02:06:40 am »
I use this one .. cheapo from china via ebay. I just stuck a piece of the tape on the flywheel and pointed it in there, worked perfectly.
Reply #4August 03, 2012, 06:21:26 am
vwsb1974
  • 81
Re: setting idle
« Reply #4 on: August 03, 2012, 06:21:26 am »
thanks for the info i will look into it ;D
