S-PAutomotive.com
Author Topic: Definite tach solution for a, sorry, ANY diesel engine  (Read 13755 times)
August 01, 2012, 11:42:03 pm
bgrunhaus
  • 8
« on: August 01, 2012, 11:42:03 pm »
Hello guys!
i belive in giving, you know, you've gave me so much(the forum and all of your contributions)
here's the info:
i want a tach on my diesel! dont we all?
i started reading and reading and reading and didnt find anything concrete!
so i decided to do it myself
i had a Crankshaft position sensor of a VR6, found the pinout online and is like this
with the two notches pointing up terminals are 1 2 3
1: 12v input
2: tach output(here you connect the tach)
3: ground
so as instructed you have to provide the 12v( better to be switched, so take it from the shut off solenoid), the ground from wherever and send a cable from the tach to the #2 terminal on the plug of the CPS.
add two nuts to the damper, welded glue whatever you like, build a bracket and that's it!
there you go!
here's a video! it's in spanish but is self explanatory! http://www.youtube.com/watch?v=DpT7qOaRco0
let me know what you think!
Reply #1August 01, 2012, 11:48:10 pm
Reply #2August 01, 2012, 11:48:24 pm
Re: Definite tach solution for a, sorry, ANY diesel engine
« Reply #2 on: August 01, 2012, 11:48:24 pm »
i built that a LONG time ago..
Reply #3August 01, 2012, 11:58:15 pm
« Reply #3 on: August 01, 2012, 11:58:15 pm »
Very well done, on both accounts. They will BOTH be added to the FAQ sticky. Kev, you probably weren't the first ever ;)lol.
Reply #4August 02, 2012, 12:08:22 am
« Reply #4 on: August 02, 2012, 12:08:22 am »
not saying i was the first.. but i was one of the first to openly confirm that it works.. and that it is very easy to accomplish..
i KNOW i was not the first, because ford used to drive their tachs off a mag pickup as well..
Reply #5August 02, 2012, 11:17:29 am
bgrunhaus
  • 8
« Reply #5 on: August 02, 2012, 11:17:29 am »
Is not that hasn't been done till now! You did it and probably a lot of guys out there have solutions too!
my contribution here is to give detailed instructions on how to wire the sensor and where to source it.
i stated that i used a volkswagen VR6 crankshaft position sensor but thinking about it the CPS of an ABA engine can be used too!
ill post an update as soon as I get the cluster tach(the cluster was changed by the PO, it now has a gas cluster) working!
Reply #6August 02, 2012, 11:39:22 am
« Reply #6 on: August 02, 2012, 11:39:22 am »
So that would power the green wire of any typical gas tachometer correct? Coooolio :)
Reply #7August 02, 2012, 01:34:06 pm
« Reply #7 on: August 02, 2012, 01:34:06 pm »
same thing with the one i built Jer.. negative side of coil to ground. positive side to tach exciter wire.. cool thing about a mag pickup, is you cant wire it wrong..
Reply #8August 18, 2012, 04:01:44 pm
bbob203
  • 1789
« Reply #8 on: August 18, 2012, 04:01:44 pm »
So this will drive a gasser mk2 tach for sure???
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #9August 31, 2012, 06:44:21 pm
« Reply #9 on: August 31, 2012, 06:44:21 pm »
in a round about way.. ive never gotten my sensor working with a stock mk2 tach.. someone has tho..
Reply #10August 31, 2012, 09:01:00 pm
bbob203
  • 1789
« Reply #10 on: August 31, 2012, 09:01:00 pm »
I'm not much with electronics. Does it require some sort of way to increase/decrease voltage or amperage/change frequency?
03 Jetta wagon TDi
Reply #11September 01, 2012, 03:17:32 pm
« Reply #11 on: September 01, 2012, 03:17:32 pm »
i dont know dude.. ive never gotten my setup working with a stock mk2 tach..
i remember something about having to use a magnetic pickup, and magnets to signal it from the crank..
just a chunk of steel doesnt make enough of a voltage spike to signal the stock tach..
that is all i know about it for now. i know mine works great with my 4" autometer tach..
Reply #12September 01, 2012, 03:21:36 pm
bbob203
  • 1789
« Reply #12 on: September 01, 2012, 03:21:36 pm »
only reason i care so much i can get a gas cluster for a dime a dozen diesel way more $$$
03 Jetta wagon TDi
Reply #13September 01, 2012, 03:23:34 pm
« Reply #13 on: September 01, 2012, 03:23:34 pm »
dakota digital tach converter..
hook the W terminal from your alt up to it, hook the green wire from it to your tach..
adjust tach for correct reading..
done deal.
Reply #14November 04, 2012, 06:36:19 pm
jimbote
  • 168
« Reply #14 on: November 04, 2012, 06:36:19 pm »
dang.... look what I found :D .... post 29!!....  http://www.vwdiesel.net/forum/index.php?topic=3741.15
S-PAutomotive.com
