Author Topic: power steering???  (Read 4476 times)
August 01, 2012, 04:51:41 am
zuki709
  • 7
power steering???
« on: August 01, 2012, 04:51:41 am »
just did a lot of work on my 91 golf 1.6 n/a. new inner outer tie rods, control arms, breaks front and rear, timing belt...ect lots of parts. i finaly got it running again after a month of put parts on it and now i have no power steering. the strange thing is there is no leaks and it is not winning, no noises at all just really hard to steer. any one have any suggestion? it worked fine befor i did all the work.
Reply #1August 01, 2012, 04:53:38 am
bbob203
  • 1789
Re: power steering???
« Reply #1 on: August 01, 2012, 04:53:38 am »
is the belt tight enough? did you forget to put it back on?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 01, 2012, 07:00:14 am
« Reply #2 on: August 01, 2012, 07:00:14 am »
fluid?
Reply #3August 01, 2012, 07:31:39 am
zuki709
  • 7
« Reply #3 on: August 01, 2012, 07:31:39 am »
yup belt is tight. was lots of fuid. i let the return line off and started the car, fluid did not gush out just the same amount of pressure as when i let the hose go. and the pump didn't start winning either. i guess it most be the pump. this is the first time i seen a pump just stop working.
Reply #4August 02, 2012, 08:36:39 pm
« Reply #4 on: August 02, 2012, 08:36:39 pm »
Thankfully they are so easy to come by, change and find. Same pump was used on literally ever Mk1-2-3 with power steering.
Reply #5August 03, 2012, 02:56:49 am
« Reply #5 on: August 03, 2012, 02:56:49 am »
I'm pretty sure the mk3 has different fittings. It's one of those problem areas when installing an AAZ in a mk2
Reply #6August 03, 2012, 03:16:33 am
bbob203
  • 1789
« Reply #6 on: August 03, 2012, 03:16:33 am »
I have working power steering setup for sale .
03 Jetta wagon TDi
