Author Topic: 1.6TD injector pump plumbing  (Read 3959 times)
July 31, 2012, 01:42:21 pm
gitkrunk
  • 31
« on: July 31, 2012, 01:42:21 pm »
hey guys i have a 1.6td injector pump... last part of the VW stamp says 081F which i am told is a turbo diesel pump.
I am working on putting the 1.6 in my suzuki samurai.. so i can't reference where all the lines went and came from... anyone have a pic that could explain this to me?
« Last Edit: July 31, 2012, 11:06:42 pm by gitkrunk »
Reply #1July 31, 2012, 05:29:45 pm
Re: 1.6TD injector pump plumbing
« Reply #1 on: July 31, 2012, 05:29:45 pm »
There is only two ;)
The one nearest the pulley that accepts the 17mm headed banjo bolt is the IN bolt, the one farthest from the pulley that is on its side with the same 17mm banjo bolt hole is the OUT. The small lines from the injectors meet up at this spot as well.
Reply #2July 31, 2012, 08:17:56 pm
« Reply #2 on: July 31, 2012, 08:17:56 pm »
You need 12 DC volts at the fuel solenoid when you want the engine to run. But that's about it. In from the filter, out back to the tank (should return to below the level of fuel in the tank) and that's about it. Gotta love the simplicity of old diesels.
Reply #3July 31, 2012, 10:53:21 pm
gitkrunk
  • 31
« Last Edit: July 31, 2012, 11:13:51 pm by gitkrunk »
Reply #4August 01, 2012, 06:11:37 am
bbob203
  • 1789
« Reply #4 on: August 01, 2012, 06:11:37 am »
what about the one at the front of the up by the pulley?
In fuel http://www.flickr.com/photos/gitkrunk/7689384652/in/photostream/
top=boost enrichemnt line bottom=boost pressure relief for aneroid http://www.flickr.com/photos/gitkrunk/7689386406/in/photostream/
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #5August 01, 2012, 06:55:33 am
« Reply #5 on: August 01, 2012, 06:55:33 am »
Make sure that the out on the pump has a bolt that is marked OUT
Reply #6August 01, 2012, 07:22:03 am
« Reply #6 on: August 01, 2012, 07:22:03 am »
First picture- Fuel in from filter
Second picture, top to bottom- small rubber boost line from turbo or intake manifold barb (depending on turbo and intake setup), little black rubber boot gets left as it is, and the bottom circle is the fuel OUT as Tyler said make sure the bolt is stamped out and looks like this one;
Reply #7August 01, 2012, 07:34:04 am
gitkrunk
  • 31
« Reply #7 on: August 01, 2012, 07:34:04 am »
awesome thanks for the info!!!! hopefully i can have this thing put togeather this weekend or next
Reply #8August 01, 2012, 10:33:15 am
« Reply #8 on: August 01, 2012, 10:33:15 am »
I didn't realize it was a turbo pump (though you did say so). The top nipple on the "spaceship" goes to the intake manifold, to give the pump manifold pressure which increases the fuel under boost. The nipple under it is vent to atmosphere.
