Author Topic: Vacuum pump question  (Read 4229 times)
July 27, 2012, 10:31:48 pm
mtnbob
  • 738
« on: July 27, 2012, 10:31:48 pm »
I have the newer style vacuum pump. Installing my vacuum pump from old engine to new engine. Are there any gaskets or o-rings that i need to use. Some illustrations show a green o-ring and some show a seal at the end of the gear. Mine seems to have neither. Anyone run into this?
96 Subaru Outback Wagon
Reply #1July 28, 2012, 06:32:23 am
Re: Vacuum pump question
« Reply #1 on: July 28, 2012, 06:32:23 am »
The older vac pump is a diaphram and has niether. The newer is a vane pump and has both. Some years had a different height oil pump and sometimes you run into issues with them not spinning the pump or not engaging the IM teeth.
If you are going from a vane to vane there are no issues and you vane pumps have both o rings.
Reply #2July 28, 2012, 09:14:21 am
mtnbob
  • 738
« Reply #2 on: July 28, 2012, 09:14:21 am »
I'm not seeing o-rings on the vacuum pump that came out of my 1.6 or on the one from my 1.6td. It almost looks like a seal is on the sealing edge of the pump where it touches the block, but it is not obvious and might just be part of the pump. I just keep seeing pics of the pump with a green o-ring.
Reply #3July 28, 2012, 10:21:01 am
Dakotakid
  • 1240
« Reply #3 on: July 28, 2012, 10:21:01 am »
Yes, there is supposed to be an o-ring (nothing fancy) in that groove exactly where you are worrying about.
Take the pump to a hardware dealer or pump place and get some o-rings which will fit in the groove. Have a few on hand. Done....no more drama.
Reply #4July 28, 2012, 04:13:16 pm
« Reply #4 on: July 28, 2012, 04:13:16 pm »
You also MUST have the seal in the bottom of the gear and the oil pump with the hole in the shaft.  If not, the vacuum pump will not work.
