Author Topic: my mk1 rabbit  (Read 10501 times)
July 21, 2012, 10:39:49 am
jeff115
  • 19
my mk1 rabbit
« on: July 21, 2012, 10:39:49 am »
 :) here is a rabbit I picked up a couple months ago. got an mk2 1.6 td, and swapped it in. Now im working on the exhaust so far i have a 3" dp, and Im waiting on a couple other bends to get here so I can finish the exhaust.
here is the car
here is the downpipe
Thats all I have so far.
« Last Edit: July 21, 2012, 10:46:59 am by jeff115 »
Reply #1July 24, 2012, 05:26:08 pm
jeff115
  • 19
Re: my mk1 rabbit
« Reply #1 on: July 24, 2012, 05:26:08 pm »
got the exhaust all done up. These are quiet once the exhaust is pointed out back.
Reply #2September 01, 2012, 01:40:59 am
Henk
  • 111
Re: my mk1 rabbit
« Reply #2 on: September 01, 2012, 01:40:59 am »
is a 3" exhaust not a little bit excessive??
I can barely fit 2.5" on my VNT20 flange, and this is an engine hoping to do 180hp
Any other plans for the golf(rabbit)?
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #3September 01, 2012, 10:10:21 am
jeff115
  • 19
Re: my mk1 rabbit
« Reply #3 on: September 01, 2012, 10:10:21 am »
maybe? it allows room to grow. i just picked up a gt2860 for it, so that 3" will help it breath a little better
Reply #4September 13, 2012, 08:06:17 pm
jeff115
  • 19
Re: my mk1 rabbit
« Reply #4 on: September 13, 2012, 08:06:17 pm »
Reply #5September 22, 2012, 04:47:22 pm
jeff115
  • 19
Re: my mk1 rabbit
« Reply #5 on: September 22, 2012, 04:47:22 pm »
Reply #6September 22, 2012, 05:16:53 pm
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
Re: my mk1 rabbit
« Reply #6 on: September 22, 2012, 05:16:53 pm »
Damn a GT2860?! If that thing doesn't spool til its time to shift, it won't be much fun...you may as well just use it in a compound setup, feed it with a K14 or something similar!  8)
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #7September 23, 2012, 11:33:28 am
jeff115
  • 19
Re: my mk1 rabbit
« Reply #7 on: September 23, 2012, 11:33:28 am »
I know, I hope its not to bad. I was spooling  t3/t04e with the stock governor, and the gt28 has a much smaller turbine wheel, and much tighter housing, with a nearly identical compressor. So it should spool considerably faster, and I will try to shim the governor next weekend which will give a much wider power band. I hope it drives ok. if not ill try something new.
Reply #8September 23, 2012, 11:34:34 am
Re: my mk1 rabbit
« Reply #8 on: September 23, 2012, 11:34:34 am »
Link in my signature if there is any concern with opening the pump to do the Governor Mod.
Reply #9September 23, 2012, 04:37:41 pm
jeff115
  • 19
Re: my mk1 rabbit
« Reply #9 on: September 23, 2012, 04:37:41 pm »
thank you I have looked over that link several times. it will be very helpful
Reply #10September 23, 2012, 07:48:46 pm
Re: my mk1 rabbit
« Reply #10 on: September 23, 2012, 07:48:46 pm »
Feel free to PM me if you have any questions :)
Reply #11September 24, 2012, 01:32:04 pm
jeff115
  • 19
Re: my mk1 rabbit
« Reply #11 on: September 24, 2012, 01:32:04 pm »
ok probably will
Reply #12September 24, 2012, 02:06:22 pm
Re: my mk1 rabbit
« Reply #12 on: September 24, 2012, 02:06:22 pm »
How was the to4e?  Do u no the specs of it?  I would expect the disco potato to spool much much faster it doesn't have an ideal compressor map but I'm curious to hear how it works.  Is it a chinese turbo?
Reply #13September 24, 2012, 07:56:03 pm
jeff115
  • 19
Re: my mk1 rabbit
« Reply #13 on: September 24, 2012, 07:56:03 pm »
yes its a chines turbo. I have used several chines turbos on this car, and been pleased with them.
specs for the t3/4 are
Compressor:
Trim:   55
A/R:   .50
Inducer:   50.50
Exducer:   76.00
Turbine:
Trim:   73
A/R:   .63
Inducer:   65.50
Exducer:   55.90
turbo kind of sucked but it would spool
Reply #14September 25, 2012, 09:39:46 am
Re: my mk1 rabbit
« Reply #14 on: September 25, 2012, 09:39:46 am »
Compressor:
Trim:   55
A/R:   .50
Inducer:   50.50
Exducer:   76.00
Turbine:
Trim:   73
A/R:   .63
Inducer:   65.50
Exducer:   55.90
the chinese turbos make me laugh, for one there is no such thing as a 55 trim t4, and then it lists inducer and exducer sizes, so you can calculate the trim yourself, and their numbers make it a 44 trim t4, again no such thing and it doesn't even match what they say, ha.  anyways  im still watching ur build here, very interesting, i don't think i'd ever run the chinese knock off stuff myself tho, id rather use used but good stuff.  not that i blame you.
