Author Topic: Just acquired a free 1.9TD any parts swap with 1.6?  (Read 3456 times)
February 16, 2006, 06:05:28 am
regcheeseman
  • 714
« on: February 16, 2006, 06:05:28 am »
The college I work for has just disposed of a 1.9TD lump. Essentially it is an AAZ bare engine with very few bits attached.
It was donated to the college years ago, used for a few demonstration lectures and then sat on a shelf.
What I am interested in is the compattability of parts with my 1.6GTD
Are the heads the same? could I build a 1.9 GTD?
Also as I'm fitting the GTD in an A1 Caddy and have the downpipe issue, I picked up the 1.9 downpipe which seems larger - anyone know if this is any use?
I dunno, spend ages looking for a TD engine then 2 come along at once!  :roll:  :lol:
Reply #1February 16, 2006, 02:48:26 pm
chrissev
  • 694
Re: Just acquired a free 1.9TD any parts swap with 1.6?
« Reply #1 on: February 16, 2006, 02:48:26 pm »
Quote from: "regcheeseman"
Does your 1.9 engine have a valve cover?  It won't fit a 1.6 so you don't need it, but I do!  If it has a valve cover and you want to sell it let me know!
Chris
Reply #2February 16, 2006, 04:31:39 pm
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« Reply #2 on: February 16, 2006, 04:31:39 pm »
Put the 1.9 in the car instead of the 1.6, I'll say that much.
The only problem you'll find is that fahrfrumpumpen is reduced.
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #3February 17, 2006, 01:02:31 am
regcheeseman
  • 714
« Reply #3 on: February 17, 2006, 01:02:31 am »
Sorry Chris I will need the valve cover if I use the rest of the 1.9
If it's any help, my NA T4 Eurovan Transporter had a similar style cover, maybe this might fit or similar from a NA 1.9 VW engine??
Bhtooefr,
Exactly what I was thinking except the 1.9 is a bare engine and needs manifolds etc and not all the bits will swap from my 1.6.
I was thinking I could swap the complete head from the 1.6 onto the 1.9 block. I've read it can be done the other way round - either that or source the required manifolds etc.
Maybe I'll just run the 1.6 for a while and slowly build the 1.9 up as a replacement...
Oh and what exactly is fahrfrumpumpen? (excuse the newb's ignorance!)
Reply #4February 17, 2006, 05:13:32 am
bhtooefr
  • 305
« Reply #4 on: February 17, 2006, 05:13:32 am »
Fahrfrumpumpen = far from pumping (fuel)
It has to do with the fuel economy of the VW diesels ;)
Reply #5February 17, 2006, 06:05:26 am
regcheeseman
  • 714
« Reply #5 on: February 17, 2006, 06:05:26 am »
I can cope with a reduction in Fahrfrumpumpen providing I see a corresponding increase in stompengrunten.
 :wink:
Reply #6February 17, 2006, 06:37:46 am
bhtooefr
  • 305
« Reply #6 on: February 17, 2006, 06:37:46 am »
Stompengruten?
That's actually fahrvergnuegen. Driving pleasure.
And that's not Engman or Gerlish. That's actual German. :D
