Author Topic: new 1.6 won't start  (Read 5568 times)
July 14, 2012, 11:20:22 pm
vegaspassat
  • 13
new 1.6 won't start
« on: July 14, 2012, 11:20:22 pm »
Hey guys, long time lurker-first time poster here.
 I just replaced the 1.5D in my rabbit with a 1.6D and now the 1.6 won't start. I put a new 3 notch head gasket in it because my protrusion ranged from .93mm to 1.2mm. I also had the head partially rebuilt. Before I had the head redone, the previous owner had a 2 notch head gasket in it and once I put it in my rabbit, it wouldn't start unless the IP was timed 180 degrees out :screwy: - that's why I took the head to a machine shop. They adjusted the intake and exhaust valve lash, replaced all of the exhaust valves and milled a VERY small amount off the head surface (.003" they said). The 1.5 I took out started right up every time, but it had low compression (around 250 in each hole) and now that i have the 3 notch head gasket in the 1.6 I range between 380 and 500, but it still won't run :banghead: Is it because the IP and injectors are different from the 1.5 to the 1.6?? Or do I need to rebuild my IP/injectors? Any help is appreciated!
Reply #1July 15, 2012, 12:01:09 am
One_punchmachinegun
  • 261
Re: new 1.6 won't start
« Reply #1 on: July 15, 2012, 12:01:09 am »
 IS there smoke when cranking? Because when I put the TD engine in my car I didnt plug in the shut off solenoid and there was no go. Dont know if that helps, maybe give a few more details of what is going on when cranking it over, or anything that comes to mind.
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #2July 15, 2012, 12:16:46 am
vegaspassat
  • 13
« Reply #2 on: July 15, 2012, 12:16:46 am »
yeah lots of black smoke. it will run if I floor it, but not easily. and it will not start if I don't touch the throttle. I forgot to say that I've timed the IP 3 times and every time it comes up correct at .032"
Reply #3July 15, 2012, 05:48:49 am
One_punchmachinegun
  • 261
« Reply #3 on: July 15, 2012, 05:48:49 am »
when it is running when you have it floored is it sputtering or anything. How does it sound when it is started and running with it floored?
Reply #4July 15, 2012, 08:09:41 am
« Reply #4 on: July 15, 2012, 08:09:41 am »
Time it to .040" or close thereby.
Reply #5July 15, 2012, 10:56:08 am
vegaspassat
  • 13
« Reply #5 on: July 15, 2012, 10:56:08 am »
I'll try to get a video up of it tonight
Reply #6July 15, 2012, 11:57:14 am
« Reply #6 on: July 15, 2012, 11:57:14 am »
"0.032 is wayyy low. 1.6 non turbo i would also say 0.040" would be much better spot.
Reply #7July 15, 2012, 01:11:04 pm
« Reply #7 on: July 15, 2012, 01:11:04 pm »
Rebuilding the head will not correct this problem. Rebuilding the pump will. You'll probably have to retime the pump 180 out to get it to run. Whether it is 180 out or not, you will be able to achieve the 0.90-1.00mm advance spec you are aiming for. Once you have confirmed that the pump is 180 out and it runs fine, there will be no negative effects. There is not a NEED to have the pump rebuilt.
Reply #8July 15, 2012, 10:16:05 pm
vegaspassat
  • 13
« Reply #8 on: July 15, 2012, 10:16:05 pm »
I'm not understanding.....you're saying that it's ok for the pump to be 180 degrees off?
edit: the battery on my camera is dead and I spent all day out at the lake so I don't feel like doing anything else tonight. I'll try to get a video up tomorrow
« Last Edit: July 15, 2012, 10:18:27 pm by vegaspassat »
Reply #9July 16, 2012, 11:03:34 pm
JamesT
  • 151
« Reply #9 on: July 16, 2012, 11:03:34 pm »
if the plunger has been installed incorrectly (pin not in line with the keyway), it will run when the timing is set 180o out. Because this doesn't affect any operation of the pump aside from which port is exposed at which point of rotation, it can continue to operate like this without any ill effects, provided that you and all future owners and repairmen are aware of this. The timing can still be adjusted using the normal procedure because plunger lift is the same for every 90o of pump rotation.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #10July 17, 2012, 12:11:28 pm
vegaspassat
  • 13
« Reply #10 on: July 17, 2012, 12:11:28 pm »
No I meant the pump was actually 180 out. I cracked the line on number one and cranked it by hand and it spit mfuel out when it when everything was at TDC compression, but would only run if the pump was 180 out from that position. In any case it doesn't matter because I found out what was wrong. I feel like SUCH an IDIOT!! The gauge I'm using is a friend's and he said that it was standard and not metric. I just took his word for it, but I was looking at it yesterday and the damn thing is metric!! I've been timing it to .32mm not .032 inches!!! So I set the IP timing to .90mm and it runs. Now the problem I have is a misfire when it's cold and lots of white smoke unil it warms up after about 2 minutes. Then it runs like a champ. The bently says it should be set at .83, do you think if I back the timing off a little it will take care of the white smoke and misfire?
Reply #11July 17, 2012, 12:34:53 pm
« Reply #11 on: July 17, 2012, 12:34:53 pm »
That's a lot of variance, did something bad happen in the lower holes?
Reply #12July 17, 2012, 12:50:01 pm
« Reply #12 on: July 17, 2012, 12:50:01 pm »
Time it to 1.00mm and see what happens. Some people have had to time old pumps all the way up to 1.15+. Usually 1.00mm will do it though.
Reply #13July 17, 2012, 01:25:35 pm
vegaspassat
  • 13
« Reply #13 on: July 17, 2012, 01:25:35 pm »
ok thank you! I will try that as soon as I get home from work today. I need to put a new valve cover gasket on it anyway because the new one is leaking already and I just put it on last night. Are the vlave cover gaskets supposed to be put on dry? Or with silicone?
Reply #14July 17, 2012, 02:28:04 pm
« Reply #14 on: July 17, 2012, 02:28:04 pm »
A dab of goo at the cam seal corners.
