Author Topic: Speedo problems  (Read 2356 times)
July 14, 2012, 09:23:59 am
dieselherb1
  • 354
Speedo problems
« on: July 14, 2012, 09:23:59 am »
Replaced 4 speed trans with 5 speed ACN trans now speedo off by 30% at least. Will a change in gears fix that? Or what can I do?
Reply #1July 14, 2012, 09:35:33 am
92EcoDiesel Jetta
Re: Speedo problems
« Reply #1 on: July 14, 2012, 09:35:33 am »
You need to swap the red speedo gear from the ACN to the cable. I swapped from an AVX to ACN and the red gear was spot on.
I had a very stubborn red gear, wouldn't come off. Had to put the old cable in a vise and hammer it off, while the green gear from the AVX yanked off easily by hand.
Reply #2July 16, 2012, 06:03:12 am
dieselherb1
  • 354
Re: Speedo problems
« Reply #2 on: July 16, 2012, 06:03:12 am »
Are you saying remove red gear from cable of the car that the ACN came from? That car has long since been crushed.
Reply #3July 16, 2012, 07:15:06 am
Re: Speedo problems
« Reply #3 on: July 16, 2012, 07:15:06 am »
Buy a new red gear. Ebay had them when I was looking. Yes the gear should get you back to normal.
Reply #4July 17, 2012, 10:45:34 am
Re: Speedo problems
« Reply #4 on: July 17, 2012, 10:45:34 am »
you need to match the speedo gear to the ring and pinion ratio..
red = 3.67
white/gray = 3.89/3.94
green = 4.25
if you dont have the right gear for the R&P you are running, then it will never be accurate.
