Author Topic: AAZ New Engine Parts  (Read 4072 times)
July 10, 2012, 12:58:16 pm
Chestrockwell
  • 95
« on: July 10, 2012, 12:58:16 pm »
All of these parts are new either opened or unopened but never installed. For AAZ VW 1.9 Turbo Diesel.
038-105-263-E Crankshaft timing pulley and new bolt
028-105-245-C Set of rod bolts 45mm long 8 pc. Opened bag but never installed.
Valve seals
059-121-119 Thermostat o-ring. Unopened bag.
misc o-rings + gaskets
08-990100-00 STD bore piston ring sets (enough for 4 cylinders). Unopened boxes (sticker has lifted over time but I never opened the boxes)
Injector seal washers
misc. bushings (I think these are for the manual shift linkages)
056-098-451A Main bearing set. Unopened box.
028-105-701J Rod bearing set. Unopened box.
068-117-021B Oil cooler. Opened box - plugs never removed.
$180 for the above lot.
All listed on Ebay so I can separate the parts as long as there are no bids.
« Last Edit: July 12, 2012, 10:35:37 pm by Chestrockwell »
