General Information
General
How to remove rtv??
Topic: How to remove rtv?? (Read 3794 times)
July 07, 2012, 01:19:46 pm
bbob203
How to remove rtv??
July 07, 2012, 01:19:46 pm »
used rtv on an oil pan last year now I wanna do it the right way and its caked on down in the elongated dimpels on the edge of pan. suggestions? this a real head to wall problem.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
July 07, 2012, 01:38:18 pm
81 vw pu
Re: How to remove rtv??
July 07, 2012, 01:38:18 pm »
Brake cleaner and a wire wheel on a drill.
July 07, 2012, 05:22:50 pm
Blocksmith
Wrench Lurker
July 07, 2012, 05:22:50 pm »
Yeah I'm voting for mechanical removal; I doubt there's any kind of solvent that'd be useful against RTV.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
July 07, 2012, 09:42:31 pm
July 07, 2012, 09:42:31 pm »
I've found that
naptha
(also called "white gasoline") seems to be the only solvent that dissolves silicone stuff well...
You're looking for either zippo lighter fluid or Coleman camp stove fuel. Both contain naptha.
July 08, 2012, 08:12:39 pm
damac
July 08, 2012, 08:12:39 pm »
i hate that stuff, it was all over a couple engines i broke down recently. they used it everywhere in addition to gaskets. intake/exhaust, seal carrier, even the damn thermostat housing haha.
i would suggest you spend the money after cleaning all that stuff up and get the all rubber gasket that you can reuse with the windage tray built in.
1985 turbo diesel jetta
July 09, 2012, 01:04:58 am
bbob203
July 09, 2012, 01:04:58 am »
One gallon of elbow grease later its all cleaned up and installed.
03 Jetta wagon TDi
General Information
General
How to remove rtv??
