Author Topic: is this head garbage?  (Read 8040 times)
June 29, 2012, 03:45:53 pm
damac
  • 531
« on: June 29, 2012, 03:45:53 pm »
would i even dare take this into a machine shop, i never dealt with this kind of stuff before.   do i take the cam and any other pieces out to reuse or are they mated to the head?  thanks!  this car kinda ran but not well, from a junkyard.  i see not even a touch on the pistons, in fact i think the bottom end from this engine is the base for my next turbo engine to go into a truck im getting.  its in better shape than the one i was running with major blowby in my jetta.
« Last Edit: July 01, 2012, 08:32:40 pm by damac »
1985 turbo diesel jetta
Reply #1June 29, 2012, 03:57:47 pm
rallydiesel
  • 1880
Re: is this head garbage?
« Reply #1 on: June 29, 2012, 03:57:47 pm »
Second pic down could be a problem. Anything is repairable, just depends on how much you want to spend. There is a guy on tdiclub named Franko6 that does aluminum weld repairs to vw cylinder heads. I think he would be your best bet. The other cracks (between the valve seats and the fine cracks in the precups) are not really a big deal and could be left as is.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2June 29, 2012, 04:12:00 pm
rs899
  • 647
« Reply #2 on: June 29, 2012, 04:12:00 pm »
Probably cheaper to find another head than to get someone to fix that one.  Cracked prechamber, too.
Reply #3June 29, 2012, 04:24:11 pm
« Reply #3 on: June 29, 2012, 04:24:11 pm »
cracked prechambers and worse the crack between the prechamber and the intake valve...Very bad. The cracks between the intake and exhaust are acceptable.
Valves/keepers/etc. maybe of some use. Cam will be usable in other heads, as long as you match it to whatever kind of head *mech or hydro* it came out of.
I would also keep the cam caps just in case you ever need one. They are not interchangable, but could be line bored if needed and used in another head.
Reply #4July 01, 2012, 02:30:16 pm
« Reply #4 on: July 01, 2012, 02:30:16 pm »
For a stock beater car I wouldn't worry about reusing the head. I'd probably buy studs instead of head bolts though just because it will likely fair sooner than a head without that crack. It's unlikely to leave you stranded on the side of the road if it does go
Reply #5July 01, 2012, 08:09:02 pm
« Reply #5 on: July 01, 2012, 08:09:02 pm »
with the crack from precup to valve... its junk... if it was onlt the precups no isssue.. but that single crack = fail..
Reply #6July 02, 2012, 07:01:51 pm
« Reply #6 on: July 02, 2012, 07:01:51 pm »
If it came off a running car I would put it back on. I wouldn't buy a head like that though.
Reply #7July 02, 2012, 10:40:21 pm
« Reply #7 on: July 02, 2012, 10:40:21 pm »
there is NO WAY i would ever re use that head, after seeing that huge crack.. its in the WRONG spot, and could leave you with a COOKED engine.
Reply #8July 03, 2012, 11:43:25 am
DRP67207
  • 50
« Reply #8 on: July 03, 2012, 11:43:25 am »
Could a crack in that location lead to coolant leaking into the cylinder?  I just pulled my head and found a crack in the same place and am trying to decide on a course of action. I suspected a head gasket, but am now afraid that this might be the root of the problem.   Thanks.
Reply #9July 03, 2012, 11:54:50 am
« Reply #9 on: July 03, 2012, 11:54:50 am »
yes.
Reply #10July 03, 2012, 01:00:26 pm
DRP67207
  • 50
« Reply #10 on: July 03, 2012, 01:00:26 pm »
Well, anyone got a cheap 1.6l na mechanical head in or near Connecticut? Looks like I'm in the market...
Reply #11July 03, 2012, 01:27:12 pm
« Reply #11 on: July 03, 2012, 01:27:12 pm »
I may have a TD head, precups are suspect. I will let you know. . . I am taking 3 heads to make one that should be great.
Reply #12July 03, 2012, 01:35:53 pm
« Reply #12 on: July 03, 2012, 01:35:53 pm »
See in this situation, unless the head was pressure checked first, I wouldn't use it again.
Reply #13July 03, 2012, 01:49:24 pm
DRP67207
  • 50
« Reply #13 on: July 03, 2012, 01:49:24 pm »
Yeah, the gasket looks okay, so I'm pretty sure it's the crack that's leaking.  Thanks for the the offer theman53, keep me posted.  Sorry for the thread jack, hope the OP has figured out his own situation.
Reply #14July 03, 2012, 11:26:17 pm
« Reply #14 on: July 03, 2012, 11:26:17 pm »
007 aka red kubvan in dec i told the owner when doing a waterpump his headgsket was suspect.. very little but noticable pressure in the coolent system at start up... like the hg was about to fail.... so in jan pulled the head to find same crack... no idea where he got his reman head.. no good trustworthy used ones to be found...
back in 07 my 1.6td b3 wagon onway home from ky started to  pressurise the cooling system after i hit 5psi... till that point no issue.. 5psi.. t would empty the coolent bottle (hole in firewall would allow my leg to get splashed, im like wtf at this point, how i found out i had a issue)... never overheated it or anything.. :( pulled head expecting bad headgasket... 2 and 3 cracked the head...
cracked heads like that may work.. but not worth melting something down..
