Author Topic: Blew my turbo feed line, help needed.  (Read 9551 times)
Reply #15June 28, 2012, 10:22:22 pm
Re: Emergency help needed!!
« Reply #15 on: June 28, 2012, 10:22:22 pm »
^+1
Reply #16June 29, 2012, 04:31:35 am
« Reply #16 on: June 29, 2012, 04:31:35 am »
yeah, i was just figuring how retarded it was gonna be to get that nut off the turbo.. stupid low mount with the EGR in the way..
Reply #17June 29, 2012, 04:48:40 am
« Reply #17 on: June 29, 2012, 04:48:40 am »
Alright so what size fittings are on either end? M10x1.0 at the filter? And at the turbo?
Reply #18June 29, 2012, 07:47:50 am
« Reply #18 on: June 29, 2012, 07:47:50 am »
banjo bolt on filter.... and since line snapped at turbo = socket... so easy on that side...
Reply #19July 01, 2012, 07:55:58 am
Re: Blew my turbo feed line, help needed.
« Reply #19 on: July 01, 2012, 07:55:58 am »
Alright, so I have had no time to do anything with the car. Sucks.
It is a banjo bolt at the filter mount, and I'm assuming it is a flared end under that female line nut. How do I go about getting a replacement? Has anyone seen these still produced OEM?
Reply #20July 01, 2012, 08:38:52 am
« Reply #20 on: July 01, 2012, 08:38:52 am »
It's a compression fitting at the turbo, not a flare.  5/16 steel ferule from McMaster will work with the stock nut/fitting.
Reply #21July 01, 2012, 08:40:10 am
« Reply #21 on: July 01, 2012, 08:40:10 am »
Thank-you sir, no for the filter end.. Can i switch it up to be a normal brake line type fitting?
Reply #22July 01, 2012, 09:22:39 am
« Reply #22 on: July 01, 2012, 09:22:39 am »
You can swap in one of the stock compression fittings from a spare flange/turbo, steal the compression nut from a spare line.  Alternatively I have tapped a non-turbo filter flange to npt and used an npt to 5/16 compression fitting.  For the tubing use 5/16 OD brake line.  Easy peasy.
Reply #23July 01, 2012, 09:25:01 am
« Reply #23 on: July 01, 2012, 09:25:01 am »
You can flare too if you have to tool.  I've done that as well.  I have a '79 rabbit that I added a vnt 15 and I used an npt to 5/16 flare fitting on the non-turbo filter flange.  The npt is easier to use than the straight thread/metal washer as it will seal even if it is not perfectly perpendicular to the flange.
Reply #24July 01, 2012, 09:37:44 am
« Reply #24 on: July 01, 2012, 09:37:44 am »
You the man. Thanks again. I took a quick look online and I found a line for $80, and a EGR block off kit for $35. From the same place as to save on shipping I would think this is a good route to go. Delete the EGR while I am in there eh.
Reply #25July 02, 2012, 07:21:23 am
« Reply #25 on: July 02, 2012, 07:21:23 am »
I prefer to make my own but that's most often because they need to be custom anyway.  $20 in parts and an hour later it's done.  YMMV.
« Last Edit: July 02, 2012, 07:25:10 am by libbydiesel »
Reply #26July 02, 2012, 09:18:26 pm
« Reply #26 on: July 02, 2012, 09:18:26 pm »
buy new line.......
the flare is a WELDED on piece of the line on my TDI feed line. its not just a simple flare. its a substantial piece of metal, quite a bit thicker than the tubing. a flare would be MUCH weaker, and i wouldnt even consider doing it..
Reply #27July 02, 2012, 09:42:55 pm
« Reply #27 on: July 02, 2012, 09:42:55 pm »
All the stock oil supply line fittings I've seen on 1.6TD, AAZ or TDI have been compression or banjo.  Flare fittings are stronger than either.  Brass flare fittings are often rated to 300 psi with brass flare fittings rated from 2,000-4,000 psi.  Regardless, any of those will handle the meager 150 psi of oil that is too thick and too cold.
Reply #28July 04, 2012, 06:30:50 pm
« Reply #28 on: July 04, 2012, 06:30:50 pm »
Ah well, I ordered a stock brand new line from IDParts.com, as well as an EGR delete kit. Shoulda done that when I had the engine out though... christ. lol
