Author Topic: Breathing/leaking mls headgasket?  (Read 3714 times)
June 24, 2012, 09:47:21 pm
kevinm
  • 78
« on: June 24, 2012, 09:47:21 pm »
I have finally got around to proving out this freshly rebuilt motor...  I have around 50km’s on this motor and am starting to poke around and look for leaks.  I have noticed on the underside of the mls headgasket, the small amount that sticks out from the block/head, a little bit of what looks like oil.  There is no dripping, just what looks like a little oil discolouration.  I did however notice one oil drip on the far side..  I have arp studs torqued to 110ft.lbs... the head and block mating surfaces were totally flat and machined... should I re-torqued the head studs? The black arrows and circle is where im noticing this... And im also wondering where the oil could be coming from in the red circle.. turbo?  probably..
Reply #1June 24, 2012, 10:42:17 pm
Re: Breathing/leaking mls headgasket?
« Reply #1 on: June 24, 2012, 10:42:17 pm »
You should have special extra-thick washers between the nuts and the exhaust manifold.  Without them present you will very likely be plagued by a self-loosening manifold.
Reply #2June 25, 2012, 05:31:14 am
« Reply #2 on: June 25, 2012, 05:31:14 am »
If the finish of the head was too coarse you can have these problems for the life of that finish. I want to say it is something silly like 10rms or less for MLS, whatever it is it needs to be smooth. If it bothers you I don't see any harm in gently checking each stud at your 110 torque.
Reply #3June 25, 2012, 05:09:49 pm
wolf_walker
  • 1205
« Reply #3 on: June 25, 2012, 05:09:49 pm »
Every one of these SOB's I've ever looked at has been weeping oil from the headgasket mating point.  I've decided it's a feature.
My current 140K 1.9L is doing the same thing and the head's never been off, and a number of the later TDI's I've seen have shown evidence of it as well.
Last head job I did I used a MLS with the copper spray stuff, it's made it to 35K and is only weeping a small amount so far.
Mentat Text Two
Reply #4June 26, 2012, 06:48:50 am
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Re: Breathing/leaking mls headgasket?
« Reply #4 on: June 26, 2012, 06:48:50 am »
Where does one get these special washers?
Sent from my DROID X2
Reply #5June 26, 2012, 08:04:32 am
« Reply #5 on: June 26, 2012, 08:04:32 am »
Part # N90095501.  Some parts places have them or the dealer.
Reply #6June 26, 2012, 08:59:29 am
rodpaslow
  • 670
« Reply #6 on: June 26, 2012, 08:59:29 am »
I saw this and was looking at the back of my block 1.6 (1992 TD) and the mls gasket does not stick out from the back of block like shown in this picture.  Is there a difference between earlier blocks or the 1.9? Mine is flush with the edge of the block once stuck on the pegs that are at the back of the block.
Reply #7June 26, 2012, 10:43:06 am
« Reply #7 on: June 26, 2012, 10:43:06 am »
probably just variations in the gasket.. ive seen some gaskets that protrude a bit more than others. the MLS gasket for my ABF follows the block. it doesnt hang out like that..
same with the MLS diesel gasket..
but, both my gaskets are Victor/Reinz..
Reply #8June 26, 2012, 02:03:35 pm
rodpaslow
  • 670
« Reply #8 on: June 26, 2012, 02:03:35 pm »
Yeah, mine were the same - Victor/Reinz.  I haven't seen any like that, that stick out.  Good to know if Victor ever stops making these.
Reply #9June 26, 2012, 02:07:41 pm
rallydiesel
  • 1880
« Reply #9 on: June 26, 2012, 02:07:41 pm »
My mls gasket also wept despite a machined deck and head. As was mentioned already, it must be very smooth. Otherwise I would just leave it. Another option is to use headgasket sealant. I believe Dave at Passenger used it successfully in his frankenbuild.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10June 26, 2012, 02:22:53 pm
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« Reply #10 on: June 26, 2012, 02:22:53 pm »
You have an ABF? A real one or an ABA 16V conversion? details!
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #11June 26, 2012, 04:25:54 pm
kevinm
  • 78
« Reply #11 on: June 26, 2012, 04:25:54 pm »
maybe my head gasket is offset to the back...  If so the forward most part of my piston could be making contact with the headgasket?  maybe i should take a look before i put anymore miles on this motor? thanks guys.lol
Reply #12June 27, 2012, 10:33:42 am
« Reply #12 on: June 27, 2012, 10:33:42 am »
no, i dont have a REAL ABF, i wish, but its just a low compression 16v ABA.. its sitting in my bedroom, on the engine stand, waiting to go in my 86 GTI.. im gonna run it on the stock CIS-Lambda thats in the car now (car runs amazing, fuel system works great) for a while, until i get the cash/need to run megasquirt.. need to find a 16v turbo manifold, and a proper sized turbo..
either that, or im getting some high compression slugs for it, some cams, and gonna throw my 45mm webers on it! i think the webers would be the coolest setup, in terms of eye candy..
