Fuel only coming from two Nozzles.
Topic: Fuel only coming from two Nozzles. (Read 2788 times)
June 23, 2012, 09:10:45 pm
shwak23
June 23, 2012, 09:10:45 pm »
I have this injection pump. It was resealed by some kid I know who had supervision of experienced people but I don't know how much they helped. I have been spinning it over with a drill and I only get fuel out of the bottom two nozzles on the back of the pump... Not the top two? Why?
June 24, 2012, 12:06:42 am
damac
Re: Fuel only coming from two Nozzles.
June 24, 2012, 12:06:42 am »
Did you push or pull fuel through the pump before turning it over or did you start dry?
1985 turbo diesel jetta
June 24, 2012, 08:35:06 am
shwak23
June 24, 2012, 08:35:06 am »
I filled it with fuel using an electric pump coming off the return line.
June 24, 2012, 09:25:31 pm
shwak23
June 24, 2012, 09:25:31 pm »
June 25, 2012, 08:24:10 am
shwak23
Re: Re: Fuel only coming from two Nozzles.
June 25, 2012, 08:24:10 am »
Could those nozzles be clogged?
Sent from my DROID X2
June 25, 2012, 08:47:49 am
June 25, 2012, 08:47:49 am »
I had that happen on a pump that I completely disassembled and reassembled. With additional cranking it all sorted itself out. Was the electric pump running the whole time you were spinning the pump?
June 25, 2012, 09:33:45 am
shwak23
June 25, 2012, 09:33:45 am »
I don't think it was. I am going to put it back on the car and try just cranking it some more. Maybe she'll work her own kinks out.
June 28, 2012, 08:43:33 pm
shwak23
June 28, 2012, 08:43:33 pm »
Fyi excessive cranking and this particular issue solved itself.
