Author Topic: honest engine swap help, N/A or TD, IDI or TDI, 87 toyota 4runner.  (Read 10326 times)
June 22, 2012, 01:55:04 pm
billybobf
  • 318
ok, so I have an 87 toyota 4runner, it currently has a 22re in it. I am HAPPY with the output of my 22re, probably around 120hp (high guess with tuning and flow upgrades)
fuel injection is so finicky and really does not like water on its electronics. I wouldnt mind a little more power, but would be ok if I didn't gain any. Right now I do not run A/C, but wouldn't mind having it later on. I currently run a low amp alternator, but have a 135amp gm three wire or four wire. Also thoughts of an on board air compressor, but this would only run when stopped, so power is of no issue there. I am looking for something RELIABLE and SIMPLE, literally an intake, an exhaust, the basic wiring and such, but I want it to look downright clean under my hood!
I really want to get good fuel mileage.
Reply #1June 22, 2012, 02:42:02 pm
Re: honest engine swap help, N/A or TD, IDI or TDI, 87 toyota 4runner.
« Reply #1 on: June 22, 2012, 02:42:02 pm »
Look at what the VW engines are rated at, as far as horsepower and then decide. You would basically be cutting your horsepower in half, to install an n/a VW diesel.
Reply #2June 22, 2012, 06:01:15 pm
Syncroincity
  • 727
« Reply #2 on: June 22, 2012, 06:01:15 pm »
I'd say AAZ 1.9 idi with performance upgrades, or M-TDI 1Z or AHU. Anything less and you won't make it up the hills. There's plenty of documentation for this swap, too.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3June 22, 2012, 06:13:13 pm
billybobf
  • 318
« Reply #3 on: June 22, 2012, 06:13:13 pm »
well, it looks as though THEMAN? moved it to non VW, thinking that a non vw diesel would be better? is there anything out htere that you would rely on? that will still get good mileage
Reply #4June 22, 2012, 06:23:53 pm
« Reply #4 on: June 22, 2012, 06:23:53 pm »
It is no big deal, but yes I moved it. I figured it would make more sense here.
Anyhow, I am looking into a jeep with a VW powerplant, look a few threads down *another reason I put it here, might have some info for you* And from what I have found the Jeep and Toyota share some bellhousing traits. I would think a very built 1.6 or a decently built 1.9 of IDI or TDI flavor would do you well. The HP from the toy engine is ok, but the torque of these diesels is where it is at. Since it isn't a direct swap I would recommend a VNT turbo with whatever you do as you will have the instant boost that will make up for any HP loss you may experience. I do not know what a 4 runner weighs??? I bet you will be fine if you like the 120 you are used to.
Reply #5June 23, 2012, 09:53:48 am
« Reply #5 on: June 23, 2012, 09:53:48 am »
you are HAPPY with the 22r? then just leave it there.. those things are GUTLESS..
drive a STOCK 3VZ v6, then tell me you are happy with the WHEEZY 22r...
this comes from a guy that has worked on probably 100 different 22r/e's... ive even BUILT a few..
they SUCK.. even this one ^ sucked on the bottom end. gutless wonder.. my stock (intake, 2 passenger side exhaust manifolds, 88 injectors and ECU, few other things, basically stock) 1989 toyota 3VZ would annhilate that twin carbd 22r..
if you want ONE SWEET 4Runner when you are done. i got 2 words for you.
Mercedes OM617...
roughly the same power output as the 22r, but ALOT more torque. plus, they sound sweet ;)
Reply #6June 23, 2012, 07:04:41 pm
billybobf
  • 318
« Reply #6 on: June 23, 2012, 07:04:41 pm »
I would be happy with that, and parts are available? and cheap enough?
what about reliability?  oh and size?
Reply #7June 23, 2012, 09:35:40 pm
« Reply #7 on: June 23, 2012, 09:35:40 pm »
You could throw a 2LT (Toyota diesel) in it.
I know some of us here don't like that engine but it was the engine that was in the Top Gear special where they submerged it in the ocean overnight and dropped it off a building and the engine still started and ran.
Reply #8June 23, 2012, 09:42:38 pm
billybobf
  • 318
« Reply #8 on: June 23, 2012, 09:42:38 pm »
yeah, whats too bad is I coulda got one cheap a while back. you know what be PERFECT for me, is a 3BT, too bad they werent made, wouldnt that be so cool, geo metro style,
Reply #9June 24, 2012, 11:26:50 am
« Reply #9 on: June 24, 2012, 11:26:50 am »
the 2Ls were JUNK..
the 2LT wasnt AS BAD, and the 5LT was finally a decent engine, so ive been told.
im still partial to the mitsu/isuzu diesels of the same time period, they were good engines. toyota was the only one who didnt have a reliable diesel engine. the SD22 was leaps and bounds better than the 2L..
Reply #10July 05, 2012, 01:24:57 pm
snakemaster
  • 405
« Reply #10 on: July 05, 2012, 01:24:57 pm »
2L are ok   but the 2LT crack heads .  MTDi your 4runner
Reply #11July 05, 2012, 01:31:40 pm
« Reply #11 on: July 05, 2012, 01:31:40 pm »
ive seen only the non-turbo crack heads..
the turbo motors dont as often crack heads, from my experiences..
the few ive seen burn down, were n/a
Reply #12July 05, 2012, 01:43:16 pm
snakemaster
  • 405
« Reply #12 on: July 05, 2012, 01:43:16 pm »
the NA do crack heads but the turbo heads seam to crack 6 to 1 from the work i have had with them , more peak preshure in the turbo same head as the NA as far as i am aware = more 2LT engines recked = boat anchors  ;)
Reply #13July 11, 2012, 03:16:46 pm
CrazyAndy
  • 739
« Reply #13 on: July 11, 2012, 03:16:46 pm »
Mercedes OM617...
This!
