Author Topic: 1.9 oil filter housing  (Read 4811 times)
June 18, 2012, 07:14:45 pm
1life2live
« on: June 18, 2012, 07:14:45 pm »
We are in the middle of swapping a 1.9 out of a quantum into my buddies 86 jetta that had a 1.6 td in it. The housing off the 1.9 was kicked to the side to work in the quantum that puts the motor in front to back. We planned on putting the oil filter housing off the 1.6 onto the 1.9 but where it bolts to the block is different. Does anyone know what will work on the 1.9 and where to get one. just curious if theres one off a gas motor that will work that i can find at a junk yard or if i need one from a 1.9 out of a golf or jetta?
Reply #1June 18, 2012, 07:17:35 pm
Re: 1.9 oil filter housing
« Reply #1 on: June 18, 2012, 07:17:35 pm »
2.0 ABA should work
Reply #2June 18, 2012, 07:21:57 pm
1life2live
« Reply #2 on: June 18, 2012, 07:21:57 pm »
really thats perfect i happen to have two of those engines in my garage i will pull one and check it out thanks
Reply #3June 19, 2012, 05:58:36 am
« Reply #3 on: June 19, 2012, 05:58:36 am »
Please let me know as I've only heard but never tried.
Reply #4June 19, 2012, 07:57:52 am
« Reply #4 on: June 19, 2012, 07:57:52 am »
IIRC there was something about a "restrictor" in the gasser mounts that the diesel didn't have...something like that. Look into it before just bolting on for sure, might be nothing, might be something.
Reply #5June 19, 2012, 10:09:29 am
Vitwagen
  • 68
« Reply #5 on: June 19, 2012, 10:09:29 am »
My first AAZ had no restrictor. The second had a restrictor. Go figure. I'll get a picture of it in a bit.
Reply #6June 19, 2012, 12:06:07 pm
« Reply #6 on: June 19, 2012, 12:06:07 pm »
anyone know what the restrictor is for? or what it feeds?
Reply #7June 19, 2012, 02:06:06 pm
Vitwagen
  • 68
« Reply #7 on: June 19, 2012, 02:06:06 pm »
Can't find it, sorry. It's basically a grub screw with a hole through the centre. It limits the supply of oil to the turbo.
Reply #8June 19, 2012, 02:14:03 pm
« Reply #8 on: June 19, 2012, 02:14:03 pm »
how? doesnt the AAZ get oil to its turbo just like a regular 1.6? i know they have block DRAINs, but i wasnt aware of a block FEED line as well..
the oil fed to the turbo comes STRAIGHT off the main oil filter flange.. from how i understand it, that restrictor feeds something in the block. the turbo oil feed comes of the filter flange BEFORE the restrictor..
the bottom hole on the block/filter flange is the inlet. the upper hole in the block/flange is the outlet. that other small hole that the grub screw restrictor feeds, idk..
Reply #9July 01, 2012, 08:31:27 am
1life2live
« Reply #9 on: July 01, 2012, 08:31:27 am »
Well we installed the 2.0 oil filter housing on the 1.9 and it fits the block fine. We moved the oil pressure sensor down to one of the unused bungs and had to get an adapter to put the feed line in at the top where it was on the 1.6 with no restrictor
