Author Topic: LDA pump fittings for running a MBC..  (Read 2392 times)
June 16, 2012, 10:09:39 am
bbob203
  • 1789
« on: June 16, 2012, 10:09:39 am »
If I were to get a few extra banjo fittings from an LDA pump top and put them onto my turbo and used them and some sort of tubing to hookup a MBC would it work? The diameter of the barb is small but it seems like it might work. The reason is I don't want to cut my hard line to install incase i ever want to take it off. With that said does any one have any extras of these they'd sell me?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1June 16, 2012, 01:26:39 pm
Re: LDA pump fittings for running a MBC..
« Reply #1 on: June 16, 2012, 01:26:39 pm »
Are you trying to delay signal to the LDA?
Reply #2June 16, 2012, 01:49:44 pm
bbob203
  • 1789
« Reply #2 on: June 16, 2012, 01:49:44 pm »
no the lda has nothing to do with it. I just wanted see if I used a couple of  the banjo barb fittings like the one that is on the pump, on the turbo in place of the hard line so I don't have to cut it up and a means to run a manual boost controller.
03 Jetta wagon TDi
Reply #3June 17, 2012, 01:55:21 am
« Reply #3 on: June 17, 2012, 01:55:21 am »
I see where you are going, I had to run a bit bigger bore fittings than that  for my MBC to work like I wanted.
I'd look for one with ~1/4" ID.
Reply #4June 17, 2012, 05:47:17 am
bbob203
  • 1789
« Reply #4 on: June 17, 2012, 05:47:17 am »
Ah ok thats exactly the answer i was looking for thanks! Where did you get the fittings?
03 Jetta wagon TDi
Reply #5June 17, 2012, 12:53:28 pm
« Reply #5 on: June 17, 2012, 12:53:28 pm »
My wastegate came with rubber hose, and I cut it in the middle.
