Author Topic: Rack and Pinion ????  (Read 4227 times)
June 15, 2012, 07:33:29 am
hippiekiller
  • 73
« on: June 15, 2012, 07:33:29 am »
Has anyone re-sealed their own steering rack? I noticed that the kits seem to be quit reasonable.....Mine pulses a bit going through corners so I thnk that it might be a leaking internal o-ring....
Also, there seems to be a few different models of rack and pinion for my 95 jetta
  I think I can get  to either  a zf-gear or a trw-gear model, are these chassis-based differences or manufacturers....thanks
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #1June 15, 2012, 08:25:35 am
Re: Rack and Pinion ????
« Reply #1 on: June 15, 2012, 08:25:35 am »
tie rods are different between the 2 brands, one is longer then the other...
Reply #2June 15, 2012, 03:41:44 pm
CrazyAndy
  • 739
« Reply #2 on: June 15, 2012, 03:41:44 pm »
One also has ribs along the outside of the rack.  I thank that's the ZF one.  And yes the ZF and TRW are different manufacturers, so buy accordingly once you know.  Someone else around here mentioned this stuff; have you used the Search function?
Reply #3June 17, 2012, 08:39:04 pm
hippiekiller
  • 73
« Reply #3 on: June 17, 2012, 08:39:04 pm »
I crawled underneath and found a few numbers, and a tag, but no identifying letters like zf or trw, just , oddly enough, usa and the audi symbol....from my research I am leaning more toward the trw rack though....
95 jetta, 2"lift
Reply #4June 18, 2012, 04:01:47 am
« Reply #4 on: June 18, 2012, 04:01:47 am »
If it has different tie rods, what could you learn from them?
Reply #5June 20, 2012, 05:55:20 am
hippiekiller
  • 73
« Reply #5 on: June 20, 2012, 05:55:20 am »
They will both work apparently, the only difference being the inner tie rod ends, and quite possibly the tie tod lengths, not a big deal if I buy a used one....the trw units seem to be a little cheaper than the zf units,, and a more readily available used....
the obvious visual differnce between the two is that the ZF is aluminum cast and so has these waffle-like markings on it, while the trw unit has a smooth steel body...
so has anybody rebuilt one of these themselves?
« Last Edit: June 20, 2012, 05:57:27 am by hippiekiller »
95 jetta, 2"lift
Reply #6June 21, 2012, 02:45:54 pm
« Reply #6 on: June 21, 2012, 02:45:54 pm »
it usually only leaks when a part destroyed a seal or some unobtainum piece fails.. i doubt you can rebuild your self due to parts/seal avalibility.. or should i say lac of..
