Author Topic: ASF reverse light switch  (Read 4457 times)
June 08, 2012, 07:38:55 pm
bbob203
  • 1789
« on: June 08, 2012, 07:38:55 pm »
if I put an asf in my 91 will I have issues with reverse light plug? read about something somewherr with an acn not working couldnt locate it though.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1June 09, 2012, 06:11:35 pm
Re: ASF reverse light switch
« Reply #1 on: June 09, 2012, 06:11:35 pm »
the ASF will have the large 6 pin switch.
your 91 takes a 2 pin switch, and has a 2 pin connector for that switch. i suppose you could hack the connector off an 85-88 golf/jetta and wire up the reverse light portion of it to a relay, that supplys power to the original switch wiring..
the old 6 pin switches were very finicky, they had the power of the back up lights run thru the switch, and the contacts would degrade over time, then quit working..
Reply #2June 10, 2012, 06:58:13 am
bbob203
  • 1789
« Reply #2 on: June 10, 2012, 06:58:13 am »
is there a tranny with the same gearing as the asf or a c n. that will have the right plug in it?
03 Jetta wagon TDi
Reply #3June 10, 2012, 09:02:48 am
« Reply #3 on: June 10, 2012, 09:02:48 am »
not that im aware of.
are you seriously afraid to do a little wiring, but will happily tackle a trans swap?!
its seriously 2 wires that need to be cut and have another plug installed..
Reply #4June 11, 2012, 07:11:30 pm
bbob203
  • 1789
« Reply #4 on: June 11, 2012, 07:11:30 pm »
basically just cut off connector and put a few spade terminals on and plug into correct terminals in trans?
03 Jetta wagon TDi
Reply #5June 13, 2012, 09:20:55 am
« Reply #5 on: June 13, 2012, 09:20:55 am »
you could do that even..
Reply #6June 13, 2012, 09:55:15 am
« Reply #6 on: June 13, 2012, 09:55:15 am »
Reply #7June 13, 2012, 09:58:51 am
« Reply #7 on: June 13, 2012, 09:58:51 am »
thats what i told him..
doing it that way takes all the electrical strain off the reverse switch, provided that the ASF switch is even still good.. theres a good chance the switch is already dead..
Reply #8June 13, 2012, 10:12:45 am
« Reply #8 on: June 13, 2012, 10:12:45 am »
i know you did.. was copy paste (was trying to not have to grab keyboard.. but ahh well)... but bbob's last reply was plug right into switch... i wanted to post it a 2nd time for him...
now a fyi...
relay
30= power
87 = to backup lights
85 ground
86 power
how i do the relay on this...
original rev light power wire to 30 and 86
other original wire goes to tail lights 87
85 then goes to switch... other side of switch goes to ground..
so you only add 2 pieces of wire per say.. its simple... not hard and will extend life of the $$$$$$ switch..
Reply #9June 13, 2012, 10:27:25 am
« Reply #9 on: June 13, 2012, 10:27:25 am »
now a fyi...
relay
30= power
85 ground
86 power
thats the primary reason i said anything about the relay trick..
i dont really have much room to talk tho.. my 86 GTI, still has original wiring and switch.. works good tho.
