Author Topic: Comparison ko3 vs 1.6td t3  (Read 6950 times)
June 02, 2012, 09:32:04 am
the4ork
  • 331
« on: June 02, 2012, 09:32:04 am »
Can anyone give a quick comparison in spool, top end and power output?
Reply #1June 02, 2012, 09:39:40 am
Re: Comparison ko3 vs 1.6td t3
« Reply #1 on: June 02, 2012, 09:39:40 am »
100% comparing apples to oranges with this..
the K03 is basically spooled off idle, and only makes ~18psi max.. generally not a good performance oriented turbo.
the T3 doesnt spool till ~3000 with stock fueling, but is capable of 30+psi.. generally more used on vehicles where performance is wanted..
what are you trying to accomplish? we will help you decide what turbo is best..
Reply #2June 02, 2012, 09:49:26 am
the4ork
  • 331
« Reply #2 on: June 02, 2012, 09:49:26 am »
It's for an 8v gas engine, Tryin to use existing factory stuff. I want 170-180hp, in boost by 2500rpm or earlier without constricting top end power
Reply #3June 02, 2012, 09:59:21 am
« Reply #3 on: June 02, 2012, 09:59:21 am »
This thread is kinda like someone going to a Vegan forum and asking how to properly cook tofu because they really want to cook a rare steak.
Reply #4June 02, 2012, 10:02:38 am
the4ork
  • 331
« Reply #4 on: June 02, 2012, 10:02:38 am »
Figured u guys would know these snails better than anyone else.
Is the diesel and gas ko3 the same?
Reply #5June 02, 2012, 10:06:32 am
« Reply #5 on: June 02, 2012, 10:06:32 am »
No they aren't the same and the diesel K03 or T3 will behave differently on a gas engine than on a diesel.  I have used all the 1.6 and 1.9 turbos except the AAZ T2 and yet I probably wouldn't have any useful info for you because I haven't used any of them on 8v gas engines.
Reply #6June 02, 2012, 10:24:04 am
the4ork
  • 331
« Reply #6 on: June 02, 2012, 10:24:04 am »
do they have the same mounting flange?
i just ask because a k03s is a very nice match for a 20v engine, so i was guessing a k03 non-s would be a great turbo for an 8v
but id also be interested in comparing the k-series as well.
all these parts are off the shelf, cheap and bolt on. so why not?
id just go aftermarket but everything is a t3 flange and id have to use a pretty small t3 i think for what id like to accomplish.
Reply #7June 02, 2012, 10:56:02 am
« Reply #7 on: June 02, 2012, 10:56:02 am »
I don't remember if the gasser k03 shares the same flange as the diesel k03.
Reply #8June 02, 2012, 11:35:14 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« Reply #8 on: June 02, 2012, 11:35:14 am »
They both have the triangular flange, can't tell if the bolt holes match on both.
<-- My M-tdi Mazda B-1800 and my other cars
Reply #9June 02, 2012, 07:12:58 pm
« Reply #9 on: June 02, 2012, 07:12:58 pm »
The t3 will work best on a gas engine
Reply #10June 02, 2012, 07:14:31 pm
« Reply #10 on: June 02, 2012, 07:14:31 pm »
Stock t3 isn't really good for 30 psi it will put out 30psi but it's not good at it haha
Reply #11June 07, 2012, 09:13:23 am
« Reply #11 on: June 07, 2012, 09:13:23 am »
I swear josh has told me about spiking 44psi...
i never said it would make 30psi GOOD, just that it would do it.
we all know that 30psi out of almost any single turbo is most likely inefficient..
Reply #12June 07, 2012, 09:39:08 am
« Reply #12 on: June 07, 2012, 09:39:08 am »
josh also has a totally different t3.
Reply #13June 07, 2012, 09:42:19 am
« Reply #13 on: June 07, 2012, 09:42:19 am »
no, were not talking the merc/hybrid/laggy turbo he has now/taking off soon.. i was talking about the stock VW t3, spiking 44psi.
this was a LONG time ago that the 44psi spike discussion happened.. like shortly after i joined the board, some 5 years ago.
Reply #14June 07, 2012, 02:55:28 pm
« Reply #14 on: June 07, 2012, 02:55:28 pm »
zukgod I believe...and his pile of turbos in the garage. Either way it was someone on here as I remember that number too.
