Fixmyvw.com
Author Topic: Timing belt tensioner pulley for 1994 AAZ  (Read 4038 times)
May 28, 2012, 03:19:21 pm
trent77
  • 217
« on: May 28, 2012, 03:19:21 pm »
So I began the Belt replacement on my AAZ. I removed the tensioner to install the new on and the new one has a smaller diameter hole for the stud to go through. I checked the box and it says it will work on 95 and up AAZ's. Are the 1994's different? Hopefully someone knows, because I sure don't. And actually the pulley is a bit different in design. Thanks for any help.
Trent
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1May 29, 2012, 10:29:27 am
Re: Timing belt tensioner pulley for 1994 AAZ
« Reply #1 on: May 29, 2012, 10:29:27 am »
They are indeed different. It's been a while since I worked on one but I'm pretty sure (90% or so) that the early AAZ uses the same tensioner as the 1.6
Reply #2June 02, 2012, 01:34:53 am
trent77
  • 217
« Reply #2 on: June 02, 2012, 01:34:53 am »
been so long since I did a 1.6. that I don't know either.. but they got me the right one, and she's up an running. Thanks. good for at least another 50k!
77 westfalia
06 GMC Duramax
Reply #3June 08, 2012, 05:30:25 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: June 08, 2012, 05:30:25 pm »
They do indeed! But often a cylinder head will come with two studs for both variations. It's just a difference in the stud. Rather odd that they made a change in the first place. Perhaps it is to do with an improved variation of the tensioner.
