Author Topic: AAZ Choke Lever Question  (Read 11596 times)
Reply #15May 27, 2012, 09:20:04 am
Re: AAZ Choke Lever Question
« Reply #15 on: May 27, 2012, 09:20:04 am »
The CS means "cold start" not choke. Gas cars have chokes - restricted air to richen fuel mix. Diesels take 100% air volume that the engine demands...no choke.
Cold Start Lever is a TIMING ADVANCE (6*)
and not in any way a choke..
Reply #16May 27, 2012, 07:53:00 pm
TonyTDTruck
  • 110
« Reply #16 on: May 27, 2012, 07:53:00 pm »
The reason the cold start is easier to pull at some times rather than others is because it advances the timing by rotating the camplate rollers.  If the camplate is positioned so that the pump is right before or during one of the pressure strokes of the plunger, then by pulling the cold start lever, you will be also pushing the plunger on it's stroke and compressing the plunger return springs.  The cold start should also be noticeably easier to pull when the engine is running because the internal pressure of the pump pushes the timing advance piston in the same direction that the cold start pushes it.
Make sense. So it looks like the best thing to do when starting is to pull the lever as you first turn the ignition key so it pulls without stressing the cable and mechanical links.
Good to know.  :)
How do you wash a pressure washer?
And did you know that the 14th floor in a
hotel is actually the 13th floor!
Reply #17May 27, 2012, 08:03:46 pm
« Reply #17 on: May 27, 2012, 08:03:46 pm »
Best is actually to pull it before shutdown.  You can actually rev it up a little and it should have almost no resistance.  Second best is pulling while cranking.
