Author Topic: Hot Engine.  (Read 2082 times)
May 19, 2012, 07:35:24 pm
One_punchmachinegun
  • 261
Hot Engine.
« on: May 19, 2012, 07:35:24 pm »
Ok so i searched this topic with little information found.Just to clarify. ;D
Ok so i just got my engine that i threw into my car running, I had to swap out the pump. Ok so new symptoms that are occurring would like to make sure i dont destroy the engine before i accually get to run it.
#1. So the engine gets HOT. Now i do know that there is a series of mini explosion going on inside there ;D but it is getting hot everywhere. the valve cover, intake manifold, ect. in a very short time ran for 20mins and within that time it got hot and i was just running it at an idle. Very concerning to me. The engine that was in the car before the swap was a N/A and i could run it for hours and be able to touch the valve cover no issue. What could this be? Now on the temp gauge its fine. I just dont want to damage anything.
#2. Clutch doesnt want to fully dis-engage?? this is not the biggest deal to me i can figure that out, with little worry.. Would be nice if someone had a little good advice. So i can't get into gears with engine running, But if started in gear and clutch all the way in it doesnt want to pull away until clutch is released?
Thanks
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1May 20, 2012, 12:04:46 am
Dakotakid
  • 1240
Re: Hot Engine.
« Reply #1 on: May 20, 2012, 12:04:46 am »
1) I sure can't put my hand on any of my valve covers once the engine has run and is up to temp. Perhaps with multiple beers in my gutt. But then, I would have to deal with the bilsters on my hand.
2) Did you put any lube (like a very light/trace amount of cv joint grease)  on your input splines of the transmission prior to assembly? Dry shaft=sticky clutch.
Reply #2May 20, 2012, 12:39:14 am
One_punchmachinegun
  • 261
Re: Hot Engine.
« Reply #2 on: May 20, 2012, 12:39:14 am »
thank you for input!
then i have a dry shaft :o
Do i have to pop of the trans and re-do it?
