Author Topic: getting ready to swap tranny  (Read 19847 times)
Reply #60June 23, 2012, 02:52:55 pm
bbob203
  • 1789
Re: getting ready to swap tranny
« Reply #60 on: June 23, 2012, 02:52:55 pm »
your A C N didn't have 100mm flanges correct?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #61June 24, 2012, 11:13:46 am
« Reply #61 on: June 24, 2012, 11:13:46 am »
NO ACN has 100mm flanges.. i had to put make mine that way..
Reply #62July 06, 2012, 07:38:30 am
92EcoDiesel Jetta
« Reply #62 on: July 06, 2012, 07:38:30 am »
well my acn is doing great! I flushed the tranny a few times
 with valvoline gl4 / gl5, then I put in pennzoil synchromesh, which stopped it from popping out of 5th. shifting into all gears is smooth,not notchy.
 does anyone know if pennzoil synchromesh is the same as gm synchromesh? pennzoil is $6.99 a qt at advance auto parts. gm synchromesh is $18.
 my acn requires adding half a liter through the speedo hole after it spills out the side filler hole. is there a spec for oil level at the speedo hole? seems like I should make a speedo hole dipstick and do all my level checking and filling from there and never have to touch that side plug again.
Reply #63July 06, 2012, 08:11:37 am
« Reply #63 on: July 06, 2012, 08:11:37 am »
if dry... 2.25 quarts... i only speedo hole my stuff..
Reply #64July 06, 2012, 11:47:18 am
« Reply #64 on: July 06, 2012, 11:47:18 am »
speedo hole FTW, 2.25 qts as well..
2 qts GL4 gear oil, and a half pint of suspended moly lube..
Reply #65July 07, 2012, 04:33:29 am
92EcoDiesel Jetta
« Reply #65 on: July 07, 2012, 04:33:29 am »
 What brand GL4 are you using? what's the moly for? wouldn't that change the friction characteristics  of the oil for the synchros?
Reply #66July 07, 2012, 05:58:45 am
« Reply #66 on: July 07, 2012, 05:58:45 am »
Reply #67July 07, 2012, 07:17:50 am
92EcoDiesel Jetta
« Reply #67 on: July 07, 2012, 07:17:50 am »
http://www.brokevw.com/020oil.html
That's a great site and I've read that one before. What I am trying to do is make it easier for any future 020 oil level checks and changes. I guess I will have to make my own speedo hole dipstick and calibrate it.
Reply #68July 07, 2012, 07:51:09 am
« Reply #68 on: July 07, 2012, 07:51:09 am »
Reply #69July 07, 2012, 08:02:52 am
92EcoDiesel Jetta
« Reply #69 on: July 07, 2012, 08:02:52 am »
this is what I did
http://www.flickr.com/photos/13558423@N02/2170694143/
That's cool. I was thinking of something similar. Have you tried to mark the speedo and read the level on the cable/ gear? That would eliminate a special tool (that can get lost).
Does anyone know the viscoisty index of the VW GL4 gear oil? The Pennzoil Synchromesh is 9.08 cSt at 100C, I've read somewhere that it may be too thin and should not be used. Anyone used Pennzoil Synchromesh longterm and have done oil analysis?
http://www.pennzoil.com/wp-content/uploads/2012/02/Synchromesh-Manual-Trans-Fluid.pdf
