Author Topic: Internal pump pressure  (Read 12147 times)
Reply #30October 05, 2013, 01:42:20 am
vako
  • 187
Re: Internal pump pressure
« Reply #30 on: October 05, 2013, 01:42:20 am »
there was lot of fiber pieces in out bolt filter.... i cleand all out. and now (with the pressure increased) i get just the right flow from furl return line ~100ml-s in 15 seconds. should i live the pressure alone or try to lower it to the point it was before i knocked the regulator?  ???
if i want to lower the pressure i will also have to change the regulator itself, as i founf out it has a crack on the top, where moving piston is located. does anyone have it for sale? :D
Reply #31October 05, 2013, 04:43:42 am
« Reply #31 on: October 05, 2013, 04:43:42 am »
I think they can still be purchased new.
If the regulator is not leaking, I'd run with it as is.  :)
Reply #32October 05, 2013, 05:08:11 am
vako
  • 187
« Reply #32 on: October 05, 2013, 05:08:11 am »
http://www.hansdieselparts.com/PumpPressureValve.htm
success :D
on monday i will show my car to diesel specialist and if he says noise is normal than i will wait for timing tool to arrive from usa and then adjust static timing + readjust pressure with the gauge and new pressure regulator
Reply #33October 05, 2013, 05:23:13 am
« Reply #33 on: October 05, 2013, 05:23:13 am »
Errm... I'd check local or EU shops for that part, before buying from that guy. (big hint)
Regarding the twitching, keep in mind the IP is sensitive to some types of vibration (very common is a loose mounting bolt by the HP section)... the change of the front pulley/harmonic balancer might have some effect there.
Reply #34October 05, 2013, 09:52:41 am
vako
  • 187
« Reply #34 on: October 05, 2013, 09:52:41 am »
maybe i 'll get some used pressure regulator from local diesel shops. i have bought ip front seal from that shop and hope it will work for 2-3 years :D
all the mounting bolts on ip are tightened well. i had loose bolt problem when i installed vw engine in my car 3 years ago, it was twitchin on high revs and pump was vibrating like crazy. bu after tightening that bolt it worked very well. i had this pulley from day one and serious twitching started few weeks ago. maybe it was out bolt problem which was clogged badly... i will test drive my car well on monday and write the summary :D
Reply #35October 05, 2013, 04:24:09 pm
« Reply #35 on: October 05, 2013, 04:24:09 pm »
what kind of fibers?  that seems strange.
Reply #36October 06, 2013, 01:15:48 am
vako
  • 187
« Reply #36 on: October 06, 2013, 01:15:48 am »
i think fibers were from main diesel filter :/
Reply #37October 12, 2013, 12:03:39 pm
vako
  • 187
« Reply #37 on: October 12, 2013, 12:03:39 pm »
few days ago car started boiling right after starting it up :D blown head gasket, new topic and pictures coming up soon i will need your advices for my rebuild :D
Reply #38October 12, 2013, 03:22:45 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #38 on: October 12, 2013, 03:22:45 pm »
there was lot of fiber pieces in out bolt filter.... i cleand all out. and now (with the pressure increased) i get just the right flow from furl return line ~100ml-s in 15 seconds. should i live the pressure alone or try to lower it to the point it was before i knocked the regulator?  Huh?
Well done, that has saved you having to buy a new pump, if the fuel overheats due to it blocking, the control collar seizes and rips itself free of the govenor linkage. ;)
When you are fixing the head gasket, wonder why VW made it impossible to remove the head without yanking the cam pulley off the crankshaft. It has always annoyed me. >:(
Good luck with doing the head.
Reply #39October 12, 2013, 08:34:53 pm
« Reply #39 on: October 12, 2013, 08:34:53 pm »
Why is the cam pulley on the crankshaft? lmao
Reply #40October 12, 2013, 09:19:01 pm
« Reply #40 on: October 12, 2013, 09:19:01 pm »
Cam pulley - camshaft Crank Pulley - Crankshaft.  Am I misunderstanding something here?  I don't remove the cam pulley when taking the head off.  It makes for a great handle.
WTH????
Reply #41October 13, 2013, 05:37:52 am
« Reply #41 on: October 13, 2013, 05:37:52 am »
You have an older engine.. the newer backing plate (iunless removed..) is in the way.
Reply #42October 13, 2013, 05:45:45 am
vako
  • 187
« Reply #42 on: October 13, 2013, 05:45:45 am »
i also have not to remove crank pulley during the head change (but i had to remove cam pulley), i'm so happy i bought pulley puller for 6$-s :D it already did a great job for me.  but anyways i'm going to change crank pulley with a newer tdi style pulley.
for more info http://www.vwdiesel.net/forum/index.php?topic=34017.0
what do you think about cylinder scoring?
Reply #43October 14, 2013, 06:00:58 am
« Reply #43 on: October 14, 2013, 06:00:58 am »
how many degrees can fuel pressure advance dynamic timing?
I can't remember where I saw it and I haven't measured it (yet)... it might be 14o crank (unless it's a Giles pump, I think he mods the case to allow more advance).
Ahhh yes, 24o is normal.
Reply #44November 01, 2013, 01:32:46 pm
smutts
  • 720
« Reply #44 on: November 01, 2013, 01:32:46 pm »
Apologies, 11 hour workday and 3 hour comute have reduced me to the point of lobotomy.
What have I started? People across the world yanking crank pulleys to do head gaskets?
Oh well, don't believe half of what you see on the web, and none of what you hear. ;)
