Author Topic: ALH TDI Turbo in an IDI  (Read 1975 times)
May 08, 2012, 07:42:01 am
ein bora
  • 377
« on: May 08, 2012, 07:42:01 am »
I have an opportunity to buy a relatively new ALH TDI turbo with manifold and I'm thinking about installing it in my 1.9 IDI. It's vacuum operated so I'm thinking it's a good thing as I will be able to adjust the boost, so other than a manual boost controller is there anything else that I will need to get or do to make it work?
Any help appreciated. Thanks.
« Last Edit: May 08, 2012, 09:03:50 am by ein bora »
If you can't take advice - then you can't be helped!
Reply #1May 08, 2012, 10:05:57 am
Blocksmith
  • 261
    Wrench Lurker
Re: ALH TDI Turbo in an IDI
« Reply #1 on: May 08, 2012, 10:05:57 am »
You're talking about a vnt, right?
Making a manual vane controller for a vnt that will function like the original system is a little more complicated than it would first seem.
Other than the vane control system, just the usual exhaust fab work (these guys have the outlet flange-->  http://www.mandrel-bends.com/catalog/flanges-custom-waterjet-cutting-36/turbo-flanges-62/vnt-15-turbo-flange-1-2-mild-steel-2445.html  ); oil supply and drain. Oh, and you'll need to block off or weld the EGR port closed. That should be it.
What turbo will it be replacing? Or are you adding on to an n/a motor?
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
